3 Wire Overhead On Roof - Electrical - DIY Chatroom Home Improvement Forum
Old 06-12-2011, 05:22 PM   #1
3 wire overhead on roof
Hi
My house 1947 has a 3wire overhead 200 amp main as far as ground is concerned should there be a visable ground wire to a rod in the ground and to a gas or water main visable because i dont see one and just want to know if i should call a electrician for safety . i do see a ground wire in my main panel though.
Tony vargas is offline   Reply With Quote
Old 06-12-2011, 05:39 PM   #2
Lic Elect/Inspector/CPO
There should be a wire from the panel to the waterline in the house, also a bonding jumper on hot water heater, as well as a wire going to at least 1 ground rod. Depending on when service was upgradewd will dictate if 1 or 2 ground rods were required.
NJMarine is offline   Reply With Quote
The Following User Says Thank You to NJMarine For This Useful Post:
Tony vargas (06-12-2011)
Old 06-12-2011, 05:48 PM   #3
I really appreciat your help i thought that is how it should be set up just wanted to make sure with a electrician because i am not that but had a idea from being around construction for a bit
Thanks again
Tony
Old 06-12-2011, 06:01 PM   #4
bonding jumper
Hey njmarine one more ? bonding jumper on hot water heater how is this done hot to cold pipe i thought this was the same as bonding jumper on incoming water main from the city. can you explain
thanks
Need opinion on this roof profenx Roofing/Siding 14 10-12-2010 01:56 AM
Strange Winter Roof Leak Dragon Roofing/Siding 16 10-09-2009 07:06 PM
Addition and Roof Replacement lebeld Roofing/Siding 4 01-04-2009 07:11 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
String Wire Thru Flat Roof Jamie Girard Roofing/Siding 3 02-18-2005 11:01 PM
