Old 05-13-2012, 09:05 PM   #1
3 wire to 4 wire for stove
I had to disconnect a 240 vac 50A range outlet to re-floor a kitchen. I noticed one lug is broken, a replacement is in order. to install a new 4 wire outlet and pigtail I known I have to remove the bonding jumper in the stove. Instead of running new 4 wire se cable, can I run a separate ground along side of the existing 3 wire cable? If it is ok, I have 8 gauge black which I can green tape, or I have 10 gauge green wire. The total run is 22 feet in a basement. I am the home owner. If it not ok, I will just replace the outlet.
thanks,
bernie
bernie963 is offline   Reply With Quote
Old 05-13-2012, 09:13 PM   #2
Electrical Contractor
You can not use an extra wire.
Replace the cable or change back to 3 wire
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Old 05-13-2012, 09:16 PM   #3
rrolleston's Avatar
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
Run xx-3 wire to the range depending on how much your range needs. But I have always used 6-3.
Please ask me about my special discount for people that shut up and stay out of my way! With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 05-13-2012, 09:23 PM   #4
Thanks, that is what I thought. What is there now is 6 gauge, so I will go with a replacent outlet and call it a day.
bernie
ceiling fan wicked97 Electrical 4 08-21-2011 09:12 AM
convert 3 wire range junction box to receptacle filby Electrical 0 06-05-2011 02:33 AM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 04:30 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
Stranded wire on screw connections BigJimmy Electrical 7 01-19-2008 03:42 PM
