3-wire 220V - Electrical - DIY Chatroom Home Improvement Forum
Old 10-17-2007, 03:35 PM   #1
3-wire 220V
In the process of upgrading my service to 200A in an older home we purchased (thanks to all for the help in the other thread). In that this home is vintage 70/80's, the 220V Range outlet is 3-wire SEU cable. Two hots and an uninsulated twisted Ground wire. I plan to upgrade this later, but for now, in order to get power restored to the house and get my service inspected and approved, I need to reattach everything. The building inspector said that 3-wire 220V services are grandfathered, so he'll pass it for now. My question, is where do I connect the unshielded ground (or is it a neutral in this case, or both)? It's a main panel so the neutral bars are bonded to ground anyway. To keep things neat, I've used a separate equip ground to land all other bare grounds. Should I connect it to the neutral bar or equip ground bar.
robertmee is offline   Reply With Quote
Old 10-17-2007, 03:44 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,970
No such thing in your panel. They are the same.
That bare wire is the neutral so if you are insistent on keeping the grounds and neutrals separate in a main panel I'd put it there.
Why you are separating the neutrals and grounds in a main panel is beyond me.
You say for neatness but that way you have grounds and neutrals crossing over all over the place.
Old 10-17-2007, 04:37 PM   #3
Thanks for the info!
As for crossing wires, actually, not. The ground bar is adjacent to the neutral bar, so the two wires go up together and one turns left (neutral) and one turns right (ground). It made for a very neat panel, but I do see the point of it being extra work since they are all one in the same. At least if I ever make it a sub panel, it's ready
Old 10-17-2007, 06:33 PM   #4
jproffer's Avatar
Rewards Points: 716
Almost. Don't forget you would still have to float the ground (remove the bonding strap) if you intend to do that.
jproffer is offline   Reply With Quote
Old 10-17-2007, 07:03 PM   #5
Correct!
Old 10-17-2007, 08:57 PM   #6
Licensed Pro
I think you mean float the neutral.
Stove Top wire capt2 Electrical 8 10-05-2007 01:41 PM
Old house, new light fixture, too many wires Persephonee Electrical 3 01-15-2007 08:58 AM
ok to leave chandelier third wire unconnected? gonzales9 Electrical 5 01-12-2006 08:10 PM
Does a 6 x 12ga wire nut exist? peeks Electrical 1 10-02-2005 09:58 AM
wire size wire to 10kw furnace? lochcarron Electrical 1 04-10-2005 07:43 PM
