3-wire 220 Plug - Electrical - DIY Chatroom Home Improvement Forum
Old 06-23-2011, 05:24 PM   #1
3-wire 220 plug
I have an industrial sewing machine with only three wires but the motor is 220. Is this unusal. do I need to put in an outlet to match the plug?
an electrican told me the wire was for 110 and I need to know if there is a 3/wire electrical 220 ? the cord has 1-green,
1-white, and 1-black wire in it.
Last edited by Sarita Meacham; 06-23-2011 at 05:53 PM. Reason: i didn'task the question correctly
Sarita Meacham is offline   Reply With Quote
Old 06-23-2011, 05:43 PM   #2
Licensed electrician
Rewards Points: 1,234
I don't know how you would run the machine without a proper receptacle for it.
Old 06-23-2011, 05:57 PM   #3
Sparkaholic
Rewards Points: 150
Send a message via Yahoo to sparks1up
It is not unusual for a professional sewing machine as in a factory setting to be 220-volts. The plug and the receptacle will need to match. If you bought this machine used or it is from another country it may not have a standard plug on its cord so you may have to change it and get a matching receptacle.
You don't sound as if you are sure what you have so I would recommend you hire an electrician to do the work.
Answers based on the mood I am in when you ask!
sparks1up is offline   Reply With Quote
Box fill and wire nuts zephed666 Electrical 7 05-02-2011 01:51 PM
help! - how do I wire a polarised USA plug?? Unregistered Electrical 7 01-05-2010 08:53 PM
Real Basic Electrical question re: neutral wire hellothere123 Electrical 22 07-21-2009 07:07 PM
Unpolarised US Type 2 Plug to UK Plug. razorcut Electrical 19 05-18-2009 10:49 AM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
