3-ways With One Pilot - Electrical - DIY Chatroom Home Improvement Forum
Old 07-05-2011, 09:25 PM   #1
jules4's Avatar
3-ways with one pilot
My parents have a cottage with an electric water tank in the bathroom. The place is often left unattended for 2-3 weeks at a time (during cottage season), so a leak in the water tank would result in the entire contents of the well being pumped into the bathroom.
To prevent this from happening I want to install a 3-way switch on the pump, with one switch located upstairs, so that the pump can be turned off when leaving the cottage. (There also needs to be a switch in the crawlspace with the pump for use when priming.)
However, I need a pilot on the upstairs 3-way so that we don't wind up with both of them turning it "off" before leaving. I couldn't find any wiring diagrams dealing with this exact situation, so I'd appreciate it if one the local wiring gurus could let me know if this is correct (ground excluded for clarity):
jules4 is offline   Reply With Quote
Old 07-05-2011, 09:48 PM   #2
Master Electrician
Rewards Points: 3,826
withdrawn
brric is online now   Reply With Quote
Old 07-05-2011, 10:38 PM   #3
joed's Avatar
Rewards Points: 12,458
It will work however you could do it with one less wire between the switches if you wish.
Old 07-05-2011, 10:42 PM   #4
jules4's Avatar
That's pretty slick - thanks Joed!
Old 07-06-2011, 12:05 PM   #5
Rewards Points: 1,506
It is a good idea to turn off the water tank (gas or electric) whenever the water is turned off. This way if something odd happens inthe water system so as to siphon all the water out of the tank the tank doesn't self destruct by running empty.
So this 3 way switch setup could be overkill as your parents would need to go to the breaker panel anyway.
Old 07-06-2011, 12:47 PM   #6
Master Electrician
Is it a water tank or a water heater?
Old 07-06-2011, 09:06 PM   #7
jules4's Avatar
Originally Posted by AllanJ View Post
It is a good idea to turn off the water tank (gas or electric) whenever the water is turned off. This way if something odd happens in the water system so as to siphon all the water out of the tank the tank doesn't self destruct by running empty.
It's electric, and they always turn the hot water tank off when they leave. Currently it does have to be turned off at the panel (which is conveniently located behind the fridge lol), but I'm going to put a 30 amp DP switch in the bathroom for them.
The problem with turning the pump off at the panel is that the only breaker that is readily accessible (by which I mean it can just be reached while standing on top of the wood bin) without pulling the fridge out from the wall is the one for the hot water tank. (The main disconnect for the entire panel is also accessible, but they don't want to turn everything off.)
It's a water heater (aka hot water tank - or perhaps I'm using the wrong terminology here?).
Old 07-06-2011, 09:11 PM   #8
joed's Avatar
The water heater and the water pump should be two completely separate circuits.
Old 07-06-2011, 09:26 PM   #9
jules4's Avatar
They are (I just misunderstood AllanJ's post if your commenting on my unedited reply to him).
Pilot light button on furnace won't turn whydonchathen HVAC 8 01-19-2015 10:40 AM
Pilot on Williams millivolt wall heater goes out every 8 to 16 hours wornways HVAC 30 06-22-2011 03:29 PM
Older Carrier Pilot Burner Problem cliffkot HVAC 23 04-29-2011 05:58 PM
Urgent! House Cold, NO heat, pilot lit (Lennox) ThatGuy23 HVAC 15 02-05-2009 09:11 PM
heat turns pilot light off tclarkmd HVAC 3 10-12-2007 09:37 AM
