Old 07-14-2012, 03:39 PM   #1
(3-way wiring) power-light-switch-switch-light
I cannot find a diagram for my setup
power-(12-2)-light-(12-2)-switch-(12-3)-switch-(12-2)-light
both switches are 3-ways
everything works, but the first light is dim. And when i take the bulb out of the first light, the second light dims.
jonny123 is offline   Reply With Quote
Old 07-14-2012, 03:50 PM   #2
MarginallyQualified
Originally Posted by jonny123 View Post
the first light is dim...
Assuming this is the ONLY place in the house this is happening:
check the voltage and all connections.
odds are something is loose
(and probably where everything ties together in that first light fixture JB)
Old 07-14-2012, 04:52 PM   #3
A "Handy Husband"
rjniles's Avatar
Can not work the way you describe- you have no way to get the neutral to the last light.
Coastal South Carolina
rjniles is offline   Reply With Quote
Old 07-14-2012, 10:12 PM   #4
that is what i read. Someone explained that i would need another 12-2 wire connecting both lights:
"=" means 14/3 and "-" means 14/2.
Power-L1-S1=S2, and L1-L2
but i did not understand how to do this
Old 07-14-2012, 11:24 PM   #5
Master Electrician
12/2 to switch 12/3 to switch 12/2 to light 12/2 to light.
Box 1 switch box
Connect whites together
Connect black from 2 wire to common screw
Connect red and black from 3 wire to traveller screws.
Box 2 switch box
Connect whites together.
Box 3 light one
Connect blacks and pigtail out to light. Connect whites and pigtail out to light.
Box 4 light two connect black and white to light.
If you add a wire between the lights to carry the fixture you'll be only useing the white from the cable. Legalities aside as an electrician I would frown on running your neutral a seperate run from its power. We aren't allowed to run a neutral in a different conduit from its hot. Not sure offhand how it works for romex runs. Someone more well versed in the nec can answer that I'm sure.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Old 07-15-2012, 08:26 AM   #6
so should i just bypass the first light with the incoming power so my sequence becomes
power-switch-switch-light-light
so the 2nd light is only connected to the 1st light
Old 07-15-2012, 08:35 AM   #7
Another 12-2 from first light to 2nd light
(3-way wiring) power-light-switch-switch-light-3-way-power-lite-switch-loop.jpg
hammerlane is offline   Reply With Quote
The Following User Says Thank You to hammerlane For This Useful Post:
jonny123 (07-15-2012)
Old 07-15-2012, 11:38 AM   #8
worked!
thanks everyone
3 way switch -OK to drop down neutral like this to light through switch box via 12/3? darlingm Electrical 9 12-22-2011 03:48 PM
3 and 4 way switches - power to first light mmrossen Electrical 3 12-04-2011 10:07 PM
2 Wires in to light, 3 Wires out, no juice on the switch prytoo Electrical 4 11-28-2011 06:24 PM
light switch wiring question. dannat Electrical 4 05-05-2011 10:11 AM
no power going to the light switch baseballfan Electrical 18 09-08-2008 06:35 PM
