3-way Wiring Position - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-21-2012, 05:08 PM   #16
Master Electrician
Rewards Points: 3,870
Originally Posted by fa_f3_20 View Post
There is no code requirement. If you're OCD like I am, you can make them so that the light is on when both are up, but it doesn't really matter.
The light would also be on if they're both down as well.
brric is offline   Reply With Quote
Old 01-21-2012, 05:22 PM   #17
Rewards Points: 3,256
Dang!!!!!!!!!!!!!!!!! and I just got finished fixing all of my 3-ways.
Noooooooo....I'm not even gonna look at my 4-way.
zappa is offline   Reply With Quote
Old 01-21-2012, 06:40 PM   #18
joed's Avatar
Rewards Points: 12,892
Originally Posted by Julius793 View Post
On a three way there is no real up or down.
There is in fact an up and down (unless you mount the switch sideways). There is no ON and OFF as that changes with use.
Old 01-21-2012, 07:02 PM   #19
Rewards Points: 77
I toiled over it, but I wired them to be "on" when the switches are in the same position. I hope I can sleep tonight.
bkvanbek is offline   Reply With Quote
Old 01-21-2012, 08:23 PM   #20
OMG LMAO this is one them being funny post.
Hardway is offline   Reply With Quote
Old 01-21-2012, 08:38 PM   #21
Rewards Points: 77
i was serious, I had a terrible time when a electrician friend used a different brand yellow wire nut than I had been using. I feel that I accomplished a lot just by not replacing them.
Old 01-21-2012, 08:40 PM   #22
Rewards Points: 77
You can bet that all the 3-ways will be wired so that they are off if in the same position.
Old 01-21-2012, 08:44 PM   #23
Licensed electrician
Rewards Points: 1,622
But one pair could be up and off while another pair is down and off.
Old 01-21-2012, 08:46 PM   #24
Rewards Points: 77
They will all be down and off or up and off. Only when the pairs are opposite will the light be on.
Old 01-21-2012, 09:08 PM   #25
Never ever ever accidently switch both at the same time or they will get out of sync and you will have to rewire them again!
Old 01-21-2012, 09:10 PM   #26
Rewards Points: 77
The 4-ways really have me worried.
Old 01-22-2012, 12:35 AM   #27
Julius793's Avatar
I knew so idiot is gona have say that
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 01-22-2012, 09:38 AM   #28
Rewards Points: 77
So with 4-ways can all switches down be off. And yes i know that if one or three or whatever are up, down can be on. But if they are all down can that be off?
Old 01-22-2012, 09:41 AM   #29
joed's Avatar
It can be setup that way.
Old 01-22-2012, 09:49 AM   #30
Electrician
SD515's Avatar
Rewards Points: 504
Though I got a chuckle out of this thread, I thought I’d throw some info out there. I have had customers request that their 3-ways be set so the lights are off when the switches are in the same position. I figured out that if you use the same switch (manufacturer/model #) for both, and orientate them the same way when mounting (example, mounted with the common terminal on the lower right), reverse the travellers at the second switch.
Example…at the first switch, attach the red traveller on the right, at the second switch attach it on the left. Has worked for me every time.
When adding a 4-way in, sometimes you might have to experiment, but IIRC keep the same traveller (red for example, incoming and outgoing) on the same side if top-to-bottom terminals, same upper or lower terminal if side-to-side terminals. Attach the other incoming traveller to the other incoming terminal of the switch (don’t cross the travellers at the 4-way).
Kyle
Attic wiring - ceiling lighting uses 14/2 cable without ground darlingm Electrical 3 11-29-2011 09:01 AM
Backyard wiring questions MikeInDetroit Electrical 1 11-02-2011 09:46 AM
Landscape wiring question: GFCI and Breaker Amp MikeInDetroit Electrical 0 11-02-2011 09:43 AM
Cloth Wiring - Replace? JessicaGus Electrical 9 09-23-2009 06:45 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 07:52 PM
