3-way Wiring Position - Electrical - DIY Chatroom Home Improvement Forum
Old 01-21-2012, 02:16 PM   #1
Rewards Points: 77
3-way wiring position
With a 3-way wiring config, with both switches up or down, should the light(s) be on or off?
bkvanbek is offline   Reply With Quote
Old 01-21-2012, 02:17 PM   #2
Julius793's Avatar
Can be either
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 01-21-2012, 02:18 PM   #3
Licensed electrician
Rewards Points: 1,766
You could also have the light on with one up and one down.
Old 01-21-2012, 02:25 PM   #4
Rewards Points: 77
Originally Posted by Julius793 View Post
Can be either
I know, but which is right? If not right or wrong, which is most common?
Old 01-21-2012, 02:33 PM   #5
Julius793's Avatar
There is no right, wrong, or common it depends on each install.
Old 01-21-2012, 02:46 PM   #6
Rewards Points: 77
This is new construction and the first of many 3-way, I want to do them all the same. What is preferred?
Old 01-21-2012, 02:52 PM   #7
It will change depending on which switch gets used.
SW1 SW2
up up = on
dn up = off
dn dn = on
dn up = off
Old 01-21-2012, 02:59 PM   #8
Julius793's Avatar
SW1 SW2
up up = on
dn up = off
dn dn = on
dn up = off
On a three way there is no real up or down.
Old 01-21-2012, 03:00 PM   #9
Julius793's Avatar
There is no preferred figure out what you like and stick with it throughout the house
Old 01-21-2012, 03:03 PM   #10
I was referring to the position of the toggles.
Old 01-21-2012, 03:06 PM   #11
Rewards Points: 77
SW1 SW2
up up = on
dn up = off
dn dn = on
dn up = off
Is this the way you wire it?
Not?
up up = off
dn up = on
dn dn = off
dn up = on
Old 01-21-2012, 03:09 PM   #12
I was trying to show that it does not matter. Changing the position of one switch turns the light either on or off.
Old 01-21-2012, 03:12 PM   #13
Rewards Points: 77
I know but wired with the travelers on way, with switches in the same position the lights will be on OR off, and that will not change. Like I said, I know there is no right or wrong. What is the preferred, on OR off if the switches are in the same position?
Old 01-21-2012, 03:40 PM   #14
Rewards Points: 240
There is no code requirement. If you're OCD like I am, you can make them so that the light is on when both are up, but it doesn't really matter.
fa_f3_20 is offline   Reply With Quote
Old 01-21-2012, 04:00 PM   #15
Rewards Points: 3,256
Thanks guys....I'm major OCD and y'all had me going around my whole house checking every 3-way out.
zappa is offline   Reply With Quote
Attic wiring - ceiling lighting uses 14/2 cable without ground darlingm Electrical 3 11-29-2011 09:01 AM
Backyard wiring questions MikeInDetroit Electrical 1 11-02-2011 09:46 AM
Landscape wiring question: GFCI and Breaker Amp MikeInDetroit Electrical 0 11-02-2011 09:43 AM
Cloth Wiring - Replace? JessicaGus Electrical 9 09-23-2009 06:45 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 07:52 PM
