3 Way Wiring Of Lights - Electrical - DIY Chatroom Home Improvement Forum
Old 09-18-2014, 01:39 PM   #1
RamblinWreck
gtrob2003's Avatar
Question
3 way wiring of lights
Guys, I'm sure this has been asked 100 times, but I'm investigating a home I just moved in to's wiring. I want to add a few more florescent lights to the garage. I thought it was going to be simple as there are only two incandescent and one switch (inside the kitchen door). However, after cutting in my hole and running most of the wire, I have found that it appears it was wired for a 3 way, but I don't know where the wires are going or how to tie in the new lights (not worrying about where the wires are going ). Neutrals ignored for now, here is what I have:
I would like to add two more lights, with a black and white wire each, but I'm not exactly sure where to tie them to, how many wires to run, or why these lights were connected this way?
gtrob2003 is offline   Reply With Quote
Old 09-18-2014, 07:44 PM   #2
DIY staff
Rewards Points: 7,174
Are you tying into the switch box or into the existing overhead light boxes?
Old 09-18-2014, 07:59 PM   #3
RamblinWreck
gtrob2003's Avatar
I'm trying to tie in to light #2. They are in a line from the North wall (switch) to the south side of the garage ceiling (light 4). I'm in the process of hanging light #3. I'm dying here. I've done tons of research, but I can't find a similar setup.
Old 09-18-2014, 08:04 PM   #4
joed's Avatar
Rewards Points: 12,450
Adding more lights by tieing into an existing light is simple. Connect to the two wires (W&B) going to the existing fixture. Don't care about any of the other wires in the box for this part.
If the existing switch only has B&W wire then it is not a three way. It appears they are using the cable red to switch the fixtures. Connect your new fixture to the white and red where the existing fixtures white and black are connected. The cable black is probably an unswitched power wire feed a receptacle or something.
Old 09-18-2014, 08:11 PM   #5
RamblinWreck
gtrob2003's Avatar
That's what I was planning on, but in my image, all of the lights are attached to Red? I was going to push the white and the red lines to the next two lights, but wasn't sure. It seems like all the whites are connected and the blacks run somewhere else? Would I be correct in assuming that, because the whites are connected to the whites on the existing two lights and the reds to the blacks on the existing two, that i just piggyback on the red and white on the #2 light and carry forward to number three and four off of that? Thanks for the help!!! Trying not to get dead.
Old 09-18-2014, 08:20 PM   #6
Electrical Contractor
jbfan's Avatar
Rewards Points: 420
Welcome gtrob!
Go Jackets!
THWG!
Back to the topic!
Yes, just attach the new wires from light 3 to the white and red wire of light 2. Ignore any other wires in the box.
The Following User Says Thank You to jbfan For This Useful Post:
gtrob2003 (09-18-2014)
Old 09-18-2014, 08:33 PM   #7
RamblinWreck
gtrob2003's Avatar
Awesome, thanks all!
Old 09-18-2014, 08:34 PM   #8
jbfan's Avatar
Rewards Points: 420
What part of GA?
Old 09-18-2014, 08:37 PM   #9
Jello Wrangler
Rewards Points: 539
3 way wiring can be confusing even after "understanding" it. Like the others have said you can just tie in the hot and neutral from the other lights and you will be good to go.
ChiTownPro is offline   Reply With Quote
The Following User Says Thank You to ChiTownPro For This Useful Post:
Old 09-18-2014, 09:10 PM   #10
RamblinWreck
gtrob2003's Avatar
Originally Posted by jbfan View Post
What part of GA?
Woodstock now. Born and raised in Marietta.
The Following User Says Thank You to gtrob2003 For This Useful Post:
jbfan (09-18-2014)
HELP!! 3 way wiring for lights with 3 zones BigSi Electrical 7 01-28-2013 10:10 PM
Wiring two switches, two lights, power from plug circuit TurboT Electrical 14 01-02-2013 08:25 AM
wiring xenon puck lights... Bagatelle Electrical 6 12-04-2011 03:05 PM
Wiring multiple outlets, switches and lights Bubski27 General DIY Discussions 3 11-09-2011 06:54 AM
Wiring Basement Recessed Lights RyanNirg Electrical 1 10-14-2010 05:40 PM
