3-way Wiring- Ceiling Fan With Remote For Two-wire Hookup - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-04-2009, 04:25 PM   #16
Electrical Contractor
kbsparky's Avatar
Just an afterthought --- make sure you don't confuse a green wire with a blue one.
I've seen too many DIY installations where they connected the green wire to a switch leg, thinking it was supposed to be blue.
Old 02-04-2009, 04:35 PM   #17
I used to work with a guy who couldn't tell green from orange.
I'm troubleshooting a dead ass lighting short, open the box and say WTF?
220/221 is offline   Reply With Quote
Old 02-04-2009, 06:32 PM   #18
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
We certainly covered the bases.....
I've spent a while but finally found the Hunter fan I installed and got the wiring diagram. Which I put up below. Using Joes diagram I believe on this particular fan/light you could wire it as he said but you would surrender remote control of the light. The red dotted wire is the remote out to the light. The purple dotted is the remote out to the fan. No pull strings for this fan.
3-way wiring- ceiling fan with remote for two-wire hookup-ceiling-fan-remote.jpg
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 02-04-2009, 06:59 PM   #19
joed's Avatar
Rewards Points: 12,426
You do better because if you bring power to a switch and run the switch cable through the fixture you need a four wire cable between the switch with the power and the fixture.
If you want to avoid the four wire cable you could bring power in a switch box, run a three wire cable to the other switch box and run a three wire cable from the switch with the power to the fixture.
The blue in the drawing represents the light wire since you said it was a blue wire.
Old 02-04-2009, 07:20 PM   #20
UAW SKILLED TRADES
Stubbie's Avatar
After seeing 220's post it does appear there is a blue wire. I wasn't sure there would be a blue coming out with the power wires. I understood the op to be saying there was only a two wire connection for power, which would make sense with a remote fan and the blue connected to the receiver wires so that there would be remote control of both the light and the fan. Joes diagram I would think would be the best if there is no remote control of the light.
Stubbie
Old 02-04-2009, 07:32 PM   #21
joed's Avatar
The OP mentioned that there was a blue wire from the light to the remote. He could just disconnect that from the remote and use to control lights via switch. Here is alternate method with power at switch.
Old 02-04-2009, 07:35 PM   #22
UAW SKILLED TRADES
Stubbie's Avatar
Joe
I certainly agree with you and that was what I was trying to convey about the Hunter diagram. I see no reason that it wouldn't work.
Stubbie
Old 02-04-2009, 10:19 PM   #23
I don't run through fixtures except for jumpers to other lights. I probably use more wire than some other people but it seems better to me.
For simplicity, I want the only thing in a fixture/fan box to be the switch leg(s).
Old 03-13-2009, 10:52 PM   #24
Wiring Fan Transmitter to 3-way switch(es)
Request Withdrawn
Last edited by n0m0renancy; 03-16-2009 at 12:43 PM. Reason: I figured it out by my self.
n0m0renancy is offline   Reply With Quote
Old 08-15-2009, 11:01 PM   #25
Need a little more info on this setup. I have a hunter fan as well. I have two three way switches wired currently one for the fan and one for the light. I still however want to use the remote. In the fan box I have a 12-3 wire. Any suggestions? Thanks
lostwages is offline   Reply With Quote
Wiring double switch for new ceiling fan toolmanwannabe Electrical 17 11-15-2011 09:34 PM
Can I run speaker wire in conduit in ceiling Leah Frances Electrical 17 01-15-2009 12:16 PM
Wiring Ceiling Box to Switch graceandhayes Electrical 1 10-23-2006 05:02 PM
Ceiling Fixture / Switch Wiring gregger Electrical 1 10-21-2006 07:47 PM
Ok to run wiring between strapping in the ceiling? peeks Electrical 5 08-29-2005 12:12 AM
