3 Way Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 10-12-2008, 02:15 AM   #1
3 way wiring
Hi, I want to wire my hall and landing lights so that both lights can be switched from either upstairs or downstairs, can someone give me an easy to understand diagram.
Regards John
jmgrain is offline   Reply With Quote
Old 10-12-2008, 08:19 AM   #2
Whatamess
The wiring is the easy part as you can see from the diagram. The hard part is running the red wire known as the "traveler" from switch to switch. Good luck
I may go home hungry, but not tired and hungry.
TazinCR is offline   Reply With Quote
Old 10-12-2008, 09:11 AM   #3
Rewards Points: 2,350
There are several methods for 3way wiring, depending on what components are where.
Old 10-12-2008, 11:36 AM   #4
Electrician
SD515's Avatar
Rewards Points: 504
Instructions to go with the above posted diagrams:
3 way switch wiring:
White from the source goes directly to the load.
Black from the source goes to the common terminal of one of the 3 way switches.
Black of the load goes to the common terminal of the other 3 way switch.
The travelers get hooked to the remaining terminals.
If you have to use a white as 'hot', it has to feed a switch and be taped black at both ends.
Use 14 gauge wire on a 15 amp circuit, 12 ga on a 20 amp circuit.
Kyle
Old 10-12-2008, 05:24 PM   #5
joed's Avatar
Rewards Points: 13,354
There are many different ways to wire 3 ways. Here is link to some of the more common.
http://www.selfhelpandmore.com/switch-outlet/3-way/
Wiring diagram for three-way switches with pilot light SaxTeacher Electrical 34 09-15-2013 07:53 AM
Electrical problem, bad wiring? mumblemouth Electrical 10 08-09-2008 11:52 AM
Replacing wiring in middle of run, ungrounded lighting circuit alexz Electrical 3 07-05-2007 08:53 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 07:52 PM
Garage - Protecting wiring installation eastment Electrical 4 11-26-2005 11:52 AM
