3 Way Timers - Electrical - DIY Chatroom Home Improvement Forum
Old 04-01-2011, 11:06 PM   #1
3 Way Timers
Have any of you guys ever wired one the 3 way in-wall digital timers, like the Aube TI072-3W, Leviton VPT24-1PZ, and Intermatic EI600C? If so, do they actually allow the other switch in the circuit to function as a normal 3-way? By normal, I mean can you use the other switch to turn the fixture on and/or off regardless whether or not the timer has switched the power on/off to the fixture?
Or do they, simply allow you a way to turn the fixture on if the timer has the fixture off, or is it viseversa, but not both?
Looking at the diagrams itís unclear, all of them except the Leviton rewire the other 3 way switch in the circuit using it as essentially a single pole switch to switch a sense wire, and do not require a 2nd traveler.
Dahammer is offline   Reply With Quote
Old 04-02-2011, 03:21 AM   #2
never
bluelans is offline   Reply With Quote
For the 'old timers' jlmran Electrical 1 03-10-2011 06:54 AM
Air exchanger. Replace room switches with timers? murray59 HVAC 17 05-12-2010 08:16 PM
two timers on one switch keano016 Electrical 3 04-06-2010 08:15 AM
Delay on Break timers rjbaiad HVAC 6 09-24-2008 05:17 AM
220v timers Doug MIll Electrical 4 09-08-2008 12:41 PM
