Old 03-06-2010, 08:25 PM   #1
3 way switches with light load on both ends
Is there any way to wire up a light off of each switch in a 3-way switch setup? I have a light at the top of my stairs that comes off the top 3 way switch. The load comes into the bottom (of the stairs) 3 way switch. It works fine currently. However, there's not enough light. I want to add another light near the bottom of the stairs, and I can get a wire back to the bottom switch. Looking at it though, I don't see any way to wire that light in to the load switch though. Is there some way to do this that I'm not thinking of? Thanks,
Ben
boutwater is offline   Reply With Quote
Old 03-06-2010, 09:27 PM   #2
Electrician
Can't be done with out adding new wire. You will have to get a new wire either from the exisitng light or the switch from where the light is fed.
darren is offline   Reply With Quote
Old 03-07-2010, 01:05 PM   #3
Electrical Contractor
If I understand, the hot reeds the top switch, and the load to the light comes from the bottom switch.
If this is correct, you may be able to add another light.
Tell us the wiring in each switch box and we can go from there.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Help me ID these switches... jp2code Electrical 10 12-11-2009 03:15 PM
Two Ceiling Light Fixture switches suddenly acting flakey!!! babalina Electrical 5 10-12-2009 08:52 PM
Please Help! 3 way switches controling 2 light fxtures. HelloMotto Electrical 50 09-01-2009 09:20 PM
adding an additional light to 2 3-way switches basement_guy Electrical 10 07-20-2008 10:23 AM
Three way light switches and double pole breaker ShawnColes Electrical 6 04-15-2008 09:25 PM
