Old 12-12-2010, 10:15 PM   #1
3 Way switches
This is the way my circuit looks. Except the switch on the bottom right I want to be a ganged box with another switch for a different light.. Do I have to run another common through since the common here is used as a Hot? The other common would be for the other light.
Kurt1968 is offline   Reply With Quote
Old 12-12-2010, 10:51 PM   #2
3 Way switches
Yes you would need a neutral. The best thing to do is just pull another circuit in instead of somehow trying to rig this. Can you tap off of the hot and neutral wires in the first (left) box?
Steelhead is offline   Reply With Quote
2 Lights & 3 switches, doesn't look right curious1 Electrical 1 10-26-2010 11:26 PM
Question about wiring and voltage with switches and lights rswurth Electrical 17 06-21-2010 12:12 AM
Question about switches on a 20 amp circuit Abs777 Electrical 6 04-28-2010 11:09 AM
Replacing switches turning into nightmare. RyanD Electrical 19 05-26-2009 07:19 PM
Need help replacing switches in four-way circuit magnolia Electrical 3 05-09-2008 10:40 PM
