3 Way Switches - Electrical - DIY Chatroom Home Improvement Forum
Old 12-19-2009, 06:52 PM   #1
3 way switches
Hello all. I'm finishing up remodeling a room in my house and picked up new receptacles and a light switch today. The only switch left that was in the color I needed is a three way; the light is a two way. I know it's probably ok to use a 3 way in a two way circuit with the only issue being I might have to rewire it if on/off aren't in the right positions. I would wire it like this: hot to common and one of the travelers to the light. Is there any problem with doing this. thanks
farrington is offline   Reply With Quote
Old 12-19-2009, 07:00 PM   #2
That is not how three way switches work. You are gonna need to go and get another switch or put in two three way switches.
Paelectrican is offline   Reply With Quote
Old 12-19-2009, 07:04 PM   #3
It would work, it's just a bad idea.
jerryh3 is offline   Reply With Quote
Old 12-19-2009, 07:06 PM   #4
Ok than i stand corrected, i just would never try it or do it in someone's home.
Old 12-19-2009, 07:08 PM   #5
Agreed. If I saw a switch w/o the ON/OFF, I would look for the mate. What color is this switch that you couldn't find another one?
Old 12-19-2009, 08:53 PM   #6
joed's Avatar
Rewards Points: 12,872
It will work just fine. There will be no problems. It not against code. It is done often when the proper switch is not available.
Old 12-19-2009, 10:32 PM   #7
Electrical Contractor
jbfan's Avatar
Rewards Points: 478
If it works backward, turn the switch upside down instead or rewiring the switch.
jbfan is online now   Reply With Quote
Old 12-19-2009, 11:10 PM   #8
Nothing wrong with doing that. Just make sure to put it in so that on is up. Also tape over the unused screw with electrical tape.
howelltc is offline   Reply With Quote
Old 12-20-2009, 06:35 AM   #9
Rewards Points: 1,512
The one and only disadvantage of using a (just one) 3 way switch for single location control is that the switch costs more. And that is chicken feed or chump change.
Help me ID these switches... jp2code Electrical 15 05-02-2015 08:52 PM
Replacing switches turning into nightmare. RyanD Electrical 19 05-26-2009 06:19 PM
50+ year old home-all light switches one-way? mudpaw Electrical 13 06-22-2008 01:57 PM
light switches wired in series -- why? magnolia Electrical 2 05-11-2008 11:16 AM
Need help replacing switches in four-way circuit magnolia Electrical 3 05-09-2008 09:40 PM
