3 Way Switches. - Electrical - DIY Chatroom Home Improvement Forum
Old 10-27-2009, 09:07 AM   #1
3 way switches.
I am finishing my basement and am at the electircal stage now. I was wanting to put the main living area on one switch, and a dimmer switch. Do I need to use 12-3 wire and run a 3 way switch, or can I use a one way switch and a dimmer?
When using 3 way switches do I run 12-3 wire to all of the lights that hook into the 3 way switches.
Any help would be greatly appreciated.
cambishop is offline   Reply With Quote
Old 10-27-2009, 09:30 AM   #2
Licensed electrician
Rewards Points: 1,788
The correct wire gauge is based on the circuit size. A 20 amp circuit would require #12, a 15 amp #14 wire.
It sounds like you want both of these switches to operate the same lights. Is this correct?
Old 10-27-2009, 09:42 AM   #3
Correct,
I want both switches to operate the same lights.
Old 10-27-2009, 11:00 AM   #4
Electrical Contractor
jbfan's Avatar
Rewards Points: 554
Power into the first switch box, 3 wire from first switch box to second switch box, 2 wire cable to first light, then to each light.
Old 10-27-2009, 11:29 AM   #5
Rewards Points: 1,542
For 3 way switching with dimming at both locations you need to buy a 3 way dimmer kit, which has both switches in it (the switches are not physically the same size).
Old 10-27-2009, 11:58 AM   #6
So I only need 12-3 to run from switch to switch, and 12-2 from light to light?
On this dimmer kit, I am only going to have on dimmer switch. At the bottom of my stairs I will have a regular 3 way switch and then the dimmer will be in the family room, both controlling the same lights.
Old 10-27-2009, 12:00 PM   #7
Do I use 3 wire to power into the first switch box or just from switch to switch? So once I go from switch to switch then I can use 12-2 to go to all of the lights? I just want to make sure I understand.
Old 10-27-2009, 12:34 PM   #8
Code05's Avatar
Rewards Points: 1,104
Power 12/2 to switch1, 12/3 from switch1 to switch2, 12/2 from switch2 to light1, 12/2 from light1 to light etc
Code05 is offline   Reply With Quote
Replacing switches turning into nightmare. RyanD Electrical 19 05-26-2009 06:19 PM
two switches that stopped working johnoh Electrical 6 03-03-2009 05:44 PM
3 switches 1 light. need 2 lights 2 switches. Im desprete s richards Electrical 6 07-19-2008 03:18 PM
light switches wired in series -- why? magnolia Electrical 2 05-11-2008 11:16 AM
Need help replacing switches in four-way circuit magnolia Electrical 3 05-09-2008 09:40 PM
