3 Way Switches - Electrical - DIY Chatroom Home Improvement Forum
Old 01-30-2013, 07:51 PM   #1
3 way switches
Ok, I need help with this one. I am finishing my basement and lighting is everything. I want to wire three switches in the same box on one circuit, and I want to make all three switches a 3 way. is this possible or am i just smoking crack? I reside in fredericksburg, va. the total watts for the circuit is 740 and that is a high estimate.
kosovofalcon is offline   Reply With Quote
Old 01-30-2013, 07:56 PM   #2
Licensed electrician
Rewards Points: 1,018
You would wire this the same as three 3 ways in single boxes except you could pigtail the incoming power to feed the 3 switches.
Old 01-30-2013, 08:28 PM   #3
is it possible to get a diagram
Old 01-31-2013, 07:25 AM   #4
Where does your electricial supply enter, at one of the switchboxes, or one (or more) of the fixtures. Or...are you completely free to run wire to anywhere at this point?
Are you familiar with three-way installation in general? My suggestion is to get onto your favorite internet seach engine and search for "three way wiring diagram". One can come up with lots of diagrams, such as:
http://www.blurtit.com/q949125.html
oberkc is offline   Reply With Quote
Old 01-31-2013, 12:58 PM   #5
Rewards Points: 2,510
here is a diagram I had saved with two three-way switches where one controls a fan motor and the other controls the light canopy on the fan. Im sure you can get the idea of just adding another 3-way switch with the first two at the left
hammerlane is online now   Reply With Quote
Old 02-02-2013, 01:51 PM   #6
Ok thanks
Old 02-02-2013, 03:35 PM   #7
Rewards Points: 1,192
3-way ,4-way ,3-way switches. Not 3 3-way.
bobelectric is offline   Reply With Quote
weird wiring and wierd voltages on 3 dual switches... meweber1000 Electrical 5 12-18-2012 01:37 PM
Two 3-way switches, one acting as a master switch? Ler0y Jenkins Electrical 10 02-28-2012 01:01 PM
Replacing old switches RyanS2000 Electrical 4 09-11-2011 04:21 PM
2 Lights & 3 switches, doesn't look right curious1 Electrical 1 10-26-2010 11:26 PM
Need help replacing switches in four-way circuit magnolia Electrical 3 05-09-2008 10:40 PM
