3 Way Switches - Electrical - DIY Chatroom Home Improvement Forum
Old 05-15-2012, 06:23 PM   #1
3 way switches
I need to wire up my plugins so that the bottom is controled by 3 way switches 1 at 1 door then plugs inbetween another door and top of plugs stay hot any ideas or diagrams??? thanks
mike cook is offline   Reply With Quote
Old 05-15-2012, 07:39 PM   #2
Licensed electrician
Rewards Points: 1,750
Is this new wiring you will be installing or is it already installed?
If it is already installed you will need to supply the routing and number and colors of all the wires in each box.
Old 05-15-2012, 09:11 PM   #3
3 way
yes this is all new starting from scratch any help apppreiated
Old 05-15-2012, 11:48 PM   #4
" Euro " electrician
frenchelectrican's Avatar
I will post one type of diagram so you can study it a little.
I will fill the details below the photo so you can understand little more.
As you noted on the J1 ( first jumper tabs ) you have to break it off to get this function properly as the photo the bottom half is switched if you want top half to be switched just reverse the black et red conductors at the receptale but leave the white alone ( at the J2 ) you will not need to break the tab at all.
If you want to " jump " to the other switched receptale so what you will do is when you hit the next receptale which you want it unswitched all the way is just hook the black conductor to the receptale and just wirenutted the red so it will go to the next receptale which you want to be half switched.
So that is one of the example you can do that way.
The materals you will need a single gang switch box with single pole switch ( let us know if you go with three way switch it will be little differnt but I will post it later if you want to go that route ) and XX-3 NM cable ( note the reason why I put XX due you may have #12 or #14 AWG conductors there so you will have check it out before you buy it. plus few junction box for downstream receptales.
There is a tip I will pass get a deep well single gang verison it will be much easier to deal with the conductors.
Note : if you did see the yellow conductor that actually a white conductor for netural so give you a head up on that.
Merci,
Marc
Old 05-16-2012, 03:22 AM   #5
3 way
yes i need 3 way switches at each end to controll 6 outlets with the top hot all the time and the bottom switched so wife can move lamps to different locations and turn them on and off from both doorways thanks
Old 05-16-2012, 06:26 AM   #6
Rewards Points: 2,516
Bottoms of the receptacles are controlled by the 3-ways and the tops of the receptacles are always hot. Put this diagram together pretty quick.....hopefully someone else can double check it. I only showed three receptacles and I believe you want six but you can get the jist of it.
Make sure the tab on the hot side of the receptacle is broken.
hammerlane is offline   Reply With Quote
Old 05-16-2012, 06:34 AM   #7
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
I highly doubt that diagram will work hammer...box fill will be big issue.
Instead of running the 3 way thru the outlets, just run it from switch to switch.
Old 05-16-2012, 06:57 AM   #8
try this:
Note: no grounds shown for ease of drawing
Old 05-16-2012, 07:05 AM   #9
k_buz's Avatar
The standard way to do it would be power to the first 3 way, a 3 wire between the switches, and a 3 wire from the first 3 way to the first outlet.
The Following 2 Users Say Thank You to k_buz For This Useful Post:
HouseHelper (05-16-2012), rjniles (05-16-2012)
Old 05-16-2012, 07:25 AM   #10
Would be no need for a 3-wire from the 2nd 3-way to the load. Just a 2-wire. But in the case the poster is proposing, by having the receptacles split throws a wrench into it.
If you can do a 3-wire between switches and a 3-wire to the receptacle with the top of the receptacle being always hot and the bottom being switched I'd like to see that.
Old 05-16-2012, 07:47 AM   #11
Rewards Points: 1,534
YOu would need to run both a 12-3 (for travelers) and a 12-2 (for raw hot) between the 3 way switches (along the bottom of the above diagram) and feed all of the receptacles around the horn from the right (second switch) using a 12-3 (switched hot, raw hot, neutral) up the right side.
The dilemma is that the neutral must follow the hot and also (2011 National Electric Code) neutral must be provided in all switch boxes.
AllanJ is online now   Reply With Quote
Old 05-16-2012, 07:50 AM   #12
k_buz's Avatar
Here's how I would do it....
Old 05-16-2012, 08:16 AM   #13
Your diagram shows power(hot & neutral) coming into the receptacle location whereas mine showed the power coming into one of the switch locations. and as you said in post #9
"The standard way to do it would be power to the first 3 way",
Old 05-16-2012, 08:18 AM   #14
Good way of putting it "raw hot". Unless of course you can find some 12-4 cable???
Old 05-16-2012, 08:52 AM   #15
Licensed Pro
This would be the preferred way, and as long as there is access to the second three-way (without the neutral) to add more wires, it will be compliant with NEC 2011.
Two 3-way switches, one acting as a master switch? Ler0y Jenkins Electrical 10 02-28-2012 12:01 PM
Wall Switches - with unknown termination cbjr Electrical 6 02-21-2012 08:15 PM
Replacing old switches RyanS2000 Electrical 4 09-11-2011 03:21 PM
Question about switches on a 20 amp circuit Abs777 Electrical 6 04-28-2010 10:09 AM
Need help replacing switches in four-way circuit magnolia Electrical 3 05-09-2008 09:40 PM
