3 Way Switch Wiring Question - Electrical - DIY Chatroom Home Improvement Forum
Old 05-06-2013, 06:43 PM   #1
Question
3 way switch wiring question
Hi
I have a question about 3 way switch. Most diagrams show that 2 14/2 wires are required between lights on a 3 way switch. I found this diagram but the website kind of looks sketchy.(I am not affiliated with it)
What do you guys think? Is this a safe diagram? I would rather use one 14/3 than 2 14/2s if possible.
Cheers
redsnapper is offline   Reply With Quote
Old 05-06-2013, 06:51 PM   #2
joed's Avatar
Rewards Points: 13,322
It will work but it has several code issues.
1. The switch on right is feeding the switched power to the light on the white. That is not allowed you must use the red or the black for that function.
2. Code in most locations currently requires a neutral wire in all switch boxes. The switch on the right does not have a neutral.
3. Single wires between lights(the extra black) are not allowed. You must use a 14/4 cable.
Old 05-06-2013, 07:07 PM   #3
Rewards Points: 150
this will not be code compliant anymore you need to bring hot and neutral to first switch then take a 14/3 to the next switch (white neutral,black and red travelers) from this switch you take a 14/2 up to the light.
usair is offline   Reply With Quote
Old 05-06-2013, 07:07 PM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,972
WHY must you run from switch to light to light to switch???
It is MUCH easier to run directly between the switches with 3-wire then up to the lights from one of them.
The Following 5 Users Say Thank You to Speedy Petey For This Useful Post:
frenchelectrican (05-06-2013), Jim Port (05-06-2013), MTN REMODEL LLC (05-06-2013), rjniles (05-06-2013), sirsparksalot (05-06-2013)
Old 05-06-2013, 07:11 PM   #5
Rewards Points: 150
that is just one way of running the circuit back in the day everything went through the light box.
Old 05-06-2013, 07:16 PM   #6
And that is one of the drawbacks of older houses. Too many switch loops and crowded fixture boxes.
The Following 3 Users Say Thank You to Speedy Petey For This Useful Post:
frenchelectrican (05-06-2013), jbfan (05-06-2013), rjniles (05-06-2013)
Old 05-06-2013, 07:24 PM   #7
Rewards Points: 150
thats why we have lots of nice service calls today the issue is the older wiring did not hold up well to the heat generated from the light fixture.
Old 05-06-2013, 08:54 PM   #8
Well that's the question. Unfortunately the electrician that designed the wiring for my basement set it up that way. Even more unfortunately I proceeded to wire the lights that way as per the diagram.
I guess my best bet it to connect the wires in one of the lights as if the light doesn't exist and run a 14/2 from the other fixture to said light.
Does that sound reasonable?
Old 05-06-2013, 08:58 PM   #9
On second though I will do it like this.
Wiring Switch For New Chandelier Haselsmasher Electrical 1 12-31-2012 12:57 PM
Wiring to Replace Timer Switch with Single Pole Switch BusterT Electrical 2 10-26-2012 03:39 PM
Any electricians? Question about a DC switch. Switch is on ground wire(s). Deck Electrical 22 01-14-2012 04:21 PM
Wiring a Ceiling Fan to a Switch that also Controlls Hot Switch timsarah Electrical 6 03-30-2010 08:14 AM
old wire, backfed switch question Jack A. Trades Electrical 6 07-03-2008 11:05 AM
