Old 08-04-2012, 12:34 PM   #1
3-way switch wiring question
I'm changing a light switch which is part of a 3 way wiring setup.
I'm only changing one switch out of the two already there.
I'm confused as to what wire is for what and my new switch has a lot of wires (its a fancy movement detector).
Any help would be appreciated.
First picture is of the switch to be replaced.
Second picture is of the "other" switch in the 3 way setup.
Third picture is of the new switch
3-way switch wiring question-3-way-switch.jpg   3-way switch wiring question-3-way-switch-2.jpg
brightlight is offline   Reply With Quote
Old 08-04-2012, 12:56 PM   #2
Licensed Electrician
k_buz's Avatar
You may not be able to use motion sensor in the box you want to. By looking at the wiring of the switches, it doesn't appear that you have a constant hot in that location. I think you only have a switch leg and travelers available.
Do you need the 3 way set up? You could rewire the switches so your motion detector is the only thing that switches the light.
Location...Location...Location
Old 08-04-2012, 12:59 PM   #3
k_buz's Avatar
Could you post the manufacturer and model #?
Old 08-04-2012, 01:26 PM   #4
Cooper Wiring Devices
OS310U Auto On Sensor (Single Output)
Here are the instructions that came with it.
Old 08-04-2012, 01:42 PM   #5
k_buz's Avatar
Thanks, I am going to need a little help on this one as it is showing you to put the neutral in the first box (second picture) to one of the traveler screws. That just doesn't make sense. You are not allowed to switch a neutral per NEC.
Old 08-04-2012, 01:51 PM   #6
I'm in Canada, does that change something?
Old 08-04-2012, 03:36 PM   #7
"So I Re-Wired It"
MisterZ's Avatar
i agree, the instructions are a bit misleading i think.
the way i see it, find the two wires (Red and Black) that come into the switch box together (paired wires)
This Black wire would nut onto the Blue traveller, and the Red would nut onto the Red traveller.
Now you have your other black, which goes to Black, and neutral and ground to their respective neutral and ground nuts.
correct me if this sounds wrong.
Knowledge is Power, but 240v can Keel You!!
MisterZ is offline   Reply With Quote
Old 08-04-2012, 04:10 PM   #8
Thanks for your help guys, but I just returned the switch to the store... :-(
Any electricians? Question about a DC switch. Switch is on ground wire(s). Deck Electrical 22 01-14-2012 05:21 PM
Changing A Double Switch to a single pole switch and a dimmer switch loydbrahn Electrical 0 11-09-2011 12:00 AM
Backyard wiring questions MikeInDetroit Electrical 1 11-02-2011 10:46 AM
Custom wiring a generator to a transfer switch robojoe_fl Electrical 4 06-08-2011 01:36 AM
old wire, backfed switch question Jack A. Trades Electrical 6 07-03-2008 12:05 PM
