3-way Switch Wiring (for Kitchen Light) - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-12-2013, 11:17 PM   #16
mikevoth's Avatar
Rewards Points: 22
My first switch is, I believe, wired correctly. 14-2 coming in, whites wire nutted together. Incoming black and outgoing black on both brass terminals. Red on the other terminal.
Second switch only has 14-3 to it, so black, white and red are on that switch.
If I understand you correctly, I shouldn't have the white on the switch, should I?
Is this box missing additional wiring to keep constant power to both switches?
mikevoth is offline   Reply With Quote
Old 04-12-2013, 11:24 PM   #17
I think (judging by the red wire in the ceiling box) that they wired the first switch the same way I do except they ran the 14-3 to the light not the other switch. And then they ran 14-3 from the light to the second switch. And have all their connections in the ceiling. And eliminate the 14-2 from the second switch to the light. There isn't anything wrong with it except it clutters the ceiling box. And in your case the white wire on the second switch is miss colored.
jsbuilders is offline   Reply With Quote
Old 04-12-2013, 11:26 PM   #18
mikevoth's Avatar
Rewards Points: 22
Since the switches have the traveler wire between them, what is preventing one switch from turning the light on when the other switch is off?
Old 04-12-2013, 11:28 PM   #19
mikevoth's Avatar
Rewards Points: 22
Is the positioning of the wires on each terminal a factor?
Old 04-12-2013, 11:30 PM   #20
My guess is on the second switch the black and white wire need to be flopped. The one on the black screw needs to be connected to the black wire on the light.
Old 04-12-2013, 11:37 PM   #21
Let me know how that works
Old 04-12-2013, 11:37 PM   #22
mikevoth's Avatar
Rewards Points: 22
That was exactly right! Works like it was intended to.
Thanks so much for your expertise! I learn a little more everyday!
Old 04-12-2013, 11:37 PM   #23
Glad I could help.
Wiring instructions for a motion sensing light switch kfwhitfo Electrical 1 03-02-2013 02:15 PM
Light in one lighted three-way switch not working dalepres Electrical 2 06-26-2012 06:27 AM
Light Wiring Question mataguri Electrical 4 11-09-2011 02:15 AM
Changing A Double Switch to a single pole switch and a dimmer switch loydbrahn Electrical 0 11-08-2011 11:00 PM
Hunter Fan Dual Switch Wiring Configuration Help schierle Electrical 2 03-29-2009 08:00 PM
