3-way Switch Wiring (for Kitchen Light) - Electrical - DIY Chatroom Home Improvement Forum
Old 04-12-2013, 04:39 PM   #1
mikevoth's Avatar
Rewards Points: 22
3-way switch wiring (for kitchen light)
I'm new here, and very green when it comes to electrical repairs. I recently bought a house built in 1966. My wife and I have repainted most all the rooms, so I thought now would be a good time to update all the switches and outlets to reflex a more modern look. The house was wired with half-hot outlets. I grew tired very quickly at switching off outlets that needed constant power, so I rewired to eliminate that headache.
The one issue I can't seem to wrap my head around is two light switches, on opposite ends of the kitchen, that control the kitchen light. When I turn off the light at one switch, I can't operate the light at the other, and visa versa.
One switch has 2 black wires and 1 red wire.
One switch has 1 black 1 red and 1 white.
Ceiling has black and white to light and red wires nutted together.
Any help would be appreciated. Thanks!!!
mikevoth is offline   Reply With Quote
Old 04-12-2013, 08:16 PM   #2
Rewards Points: 13,960
How it's done depends on if the power comes to the switch or the fixture,
here's one way.
http://www.bing.com/images/search?q=...electedIndex=0
Just Google 3 way switch wiring for other ways.
Old 04-12-2013, 08:31 PM   #3
Look it up on YouTube. I've found atleast 7 ways to wire a 3way
jsbuilders is offline   Reply With Quote
Old 04-12-2013, 08:33 PM   #4
mikevoth's Avatar
Rewards Points: 22
This is almost identical to my wiring. Only difference is, the one switch that has the power coming in, utilizes both black wires on one side, and the red on the other. 2nd switch utilizes 1 black, red and white.
Old 04-12-2013, 08:41 PM   #5
The black wire that goes the the screw (usually black) is your ungrounded aka hot, live what ever you want to call it, the white wire is the grounded aka common, neutral. Across from that is your red wire call a runner or jumper. The white wire and red wire don't matter what screw you put them on as long as they are matching on both switches. The switch that has 2 black wires still only has one live, so the other black wire is really the white. Does that make sense? If not ill re explain the best I can
Old 04-12-2013, 08:46 PM   #6
mikevoth's Avatar
Rewards Points: 22
That's the issue. I only have one white wire on one switch. Other switch has 2 blacks and a red.
Old 04-12-2013, 08:52 PM   #7
mikevoth's Avatar
Rewards Points: 22
Sorry, power comes in at one switch, not the light.
Old 04-12-2013, 08:53 PM   #8
Can you take pictures?
Old 04-12-2013, 08:56 PM   #9
mikevoth's Avatar
Rewards Points: 22
I will gladly take pictures as soon as I return home
Old 04-12-2013, 08:59 PM   #10
I'll be waiting
Old 04-12-2013, 09:00 PM   #11
mikevoth's Avatar
Rewards Points: 22
I really appreciate it.
Old 04-12-2013, 10:30 PM   #12
mikevoth's Avatar
Rewards Points: 22
Here are the pix.
3-way switch wiring (for kitchen light)-image-367525320.jpg   3-way switch wiring (for kitchen light)-image-3973948784.jpg   3-way switch wiring (for kitchen light)-image-2430873790.jpg
Old 04-12-2013, 10:41 PM   #13
The white wire in the first pic, that's just wire nutted to another white wire, right?
Old 04-12-2013, 10:53 PM   #14
mikevoth's Avatar
Rewards Points: 22
Yes, it's a 3-gang box. Multiple white wires together.
Old 04-12-2013, 11:09 PM   #15
Ok the whites always get wired together on a switch. And on the infeed of a 3 way. That's how it supplies natural all the time. The black goes to the switch and that's how it cuts the power when you flip the switch. The red is a runner that way the other switch can still get power even though the first switch is off.
The way we always do it is we have 14-2 come into the box(live infeed), black wire to the black screw on the switch. The white wire connects to a white wire in a 14-3 that runs to the other switch. The red and black wire go to the other other 2 screws on the switch. Now at the second switch we run 14-2 to the light. The whites get wired together. The black that goes to the ligh goes on the black screw, and the black and red from the 14-3 go on the other 2.
Wiring instructions for a motion sensing light switch kfwhitfo Electrical 1 03-02-2013 02:15 PM
Light in one lighted three-way switch not working dalepres Electrical 2 06-26-2012 06:27 AM
Light Wiring Question mataguri Electrical 4 11-09-2011 02:15 AM
Changing A Double Switch to a single pole switch and a dimmer switch loydbrahn Electrical 0 11-08-2011 11:00 PM
Hunter Fan Dual Switch Wiring Configuration Help schierle Electrical 2 03-29-2009 08:00 PM
