3-way Switch Wiring -- How To Fix - Electrical - Page 4 - DIY Chatroom Home Improvement Forum
Old 04-11-2014, 02:02 PM   #46
joed's Avatar
Rewards Points: 12,890
When I went to the breaker panel and tried resetting the breaker for that circuit, it immediately tripped.
Confirms my new diagram should be the one of how it is connected. The colours of the wires used may not be exactly the same as shown. If you open the fixture you should be able trace the colours and compare them to the diagram.]
The black screw on the switch is the COMMON. The gold or silver ones are the travellers.
Old 04-11-2014, 07:30 PM   #47
I looked inside the light fixture.
There are just two 3-wire cables coming into the box. White from one (guessing switch A) spliced with white from fixture.
Reds are spliced together.
Black from suspected A cable spiced with white from other 3-wire cable (B).
Black from B cable spliced with black from fixture.
So black in switch B should be on common, correct?
Is it possible I have a defective switch?
Cannot turn the power off now and out of town most of tomorrow, but I will check in when I can.
Jimbo
JimboDIY is offline   Reply With Quote
Old 04-11-2014, 09:55 PM   #48
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 2,834
Jimbo
yes,,given your analysis.... black switch B to common
Anything is possible.... but highly unlikely any new switch is bad.
Good going .... I think you have it...... and that certainley was one way to test the 2 wire in A..... There are safer ways..... but that got the job done with no harm.
Glad no harm.......
If you have other wiring issues, invest in a multi-meter. For injstance, I'm not even sure how that circut tester light works... for instance, does it light up for any amount of voltage, does it light greater/brighter with greater voltage.
Anyone know.... ???
Best
MTN REMODEL LLC is offline   Reply With Quote
Old 04-13-2014, 10:10 AM   #49
success !!
I am happy to let everyone who has tried to help solve this challenge that my 3-way switches are now BOTH working as they are supposed to.
Since we confirmed that power comes through switch A and I opened up the light to see how things are connected, I have remained puzzled. The wires were -- I thought -- all connected as per JoeD's latest diagram, and have been since before my first post here. So I went at this again this morning....
I used my new Multimeter to take some measurements,and could figure out why in one state none of the wires in Switch B was really hot. And then I remembered MTN Remodel suggesting that I look on the back of the switches for embossed labelling of Common. Guess what? Switch A's black screw was not in the Common terminal. Someone must have played with it and then returned it to HD. So I wasn't entirely off when I asked if I had a defective switch. Not defective, but not factory settings. So I changed the black screw to Common, attached the wires as per JoeD, and turned the juice back on. Everything works.
Thanks a lot to everyone who posted their ideas and explanations. The net of this is I now have a much clearer understanding of how 3-way switches work, and the different ways of wiring them. Sorry to not have followed Mtn Remodel's suggestion earlier.
Jimbo
The Following User Says Thank You to JimboDIY For This Useful Post:
MTN REMODEL LLC (04-13-2014)
Old 04-13-2014, 10:52 AM   #50
Jimbo
Way to stay with it JIMBO...... it's just a fun puzzle some of the time
Old 04-13-2014, 05:16 PM   #51
Rewards Points: 808
I just want it on record I solved it back on post #36...
IslandGuy is offline   Reply With Quote
Old 04-13-2014, 05:41 PM   #52
I am
Just for the record I solved it at #34..... thats what the xxxxxxx's are, but I erased..
kidding, you got it...
just for you... :- )
UnclePhil is offline   Reply With Quote
Old 04-13-2014, 06:02 PM   #53
AND JIMBO..... Ya got a new MM out of it.... that's the best part.!!!!
Old 04-13-2014, 06:05 PM   #54
Well UncP.... You did have a good test for the breaker.... it works good...
Old 04-13-2014, 06:21 PM   #55
Yes ... UnclePhil ... you did have a pretty good handle on it for sure. Once I knew there were only 2 3-wire cables going through the lamp, I was on my way.
But everyone helped! I got a MM to boot, and found some very cool people too.
... Jimbo
Tags
3 way switch problem
Help Wiring Dimmer Switch scubakathy84 Electrical 2 12-21-2011 10:26 PM
Simple question regarding Wall Switch wiring kebrein Electrical 6 11-25-2011 07:54 PM
Wiring an Intermatic Wall Timer in a three way switch aitutaki98 Electrical 6 07-23-2011 11:43 AM
Unusual three way switch wiring help r1racer Electrical 9 11-11-2010 08:49 PM
Switch on K&T wiring - OK to pigtail? fdmillion Electrical 4 01-27-2010 09:15 AM
