3 Way Switch - Two Sources - Electrical - DIY Chatroom Home Improvement Forum
Old 02-08-2010, 04:19 PM   #1
3 way switch - two sources
Hi,
Currently I have two different light fixtures powered by 2 different sources.
I would like to wire the two light fixtures together (handle them as one light), and somehow use 3 way switches to control the light from both places.
Although both switches have 14-2 wire installed, I could replace one of them with a 14-3 wire (to change the other switch's wiring would be a lot of trouble, and not an option at the moment). I also have free access to the light fixtures' wiring.
Is it possible to install a 3 way switch in this scenario (with 14-2 wire from one switch) ?
Thank you.
szmaria is offline   Reply With Quote
Old 02-08-2010, 05:28 PM   #2
Rewards Points: 502
Negative. You will need 14/3 from each switch.
-Andrew
DIY hobbiest
AndrewF is offline   Reply With Quote
Old 02-08-2010, 06:31 PM   #3
joed's Avatar
Rewards Points: 11,998
Or you could look for wireless controllers.
http://www.smarthome.com/2533T/Wirel...HW2155D/p.aspx
http://www.nextag.com/wireless-3_-_w...itch/shop-html
Old 02-08-2010, 08:12 PM   #4
you will have to run a wire from light to light. Then run 14/3 from switch box to the other switch box
longbeach1125 is offline   Reply With Quote
Old 02-08-2010, 10:45 PM   #5
Just call me Andrew
Rewards Points: 1,020
You DO need 3-conductor wire in each switch box, or use wireless like joed suggested.
Andrew
secutanudu is offline   Reply With Quote
Old 02-09-2010, 11:14 AM   #6
Thank you all for your answers.
I'm going to check out the wireless switches.
Just a thought before I go ahead:
The two sources are on the same breaker. Would it work if I carry only the hot from the 14-2 into the other switch (I'd mark the white wire as hot), and the neutral from the other source?
Is this in line with the code?
Old 02-09-2010, 11:39 AM   #7
Just call me Andrew
Nope, the hot/neutral have to be run together.
Andrew
Old 02-09-2010, 11:42 AM   #8
joed's Avatar
You still need three wires at the switches. You said that was not possible.
If you can get three wires to the switch there are many ways to make it work.
Tags
3 way switch
Light switch installation problems pc_clone Electrical 8 11-30-2009 10:25 PM
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 04:06 PM
4 way switch confusion Richo Electrical 10 04-09-2009 08:11 AM
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 07:14 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 02:19 AM
