3-way Switch Stopped Working? - Electrical - DIY Chatroom Home Improvement Forum
Old 11-20-2012, 05:09 PM   #1
Caution! Girl working
3-way switch stopped working?
Hello
I have a 3-way switch which lets me turn on the stairwell light from either the top of the steps or the bottom.
While building out the area around the downstairs switch I tied the switch with it's metal box and conduit off to the side and both switches worked just fine for months like that.
When I was done with the carpentry work, I pulled the light switch back and mounted it very close to where it was originally. Now, though, the switch at the top of the stairs always works but the switch at the bottom of the stairs only works if the one at the top of the stairs in the down position.
What happened? The house was built in the 50s, the wiring is in metal conduit and and has been given a clean bill of health by a wonderful electrician. Any ideas?
ADaniLion is offline   Reply With Quote
Old 11-20-2012, 05:11 PM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Loose connection or bad switch
Old 11-20-2012, 05:17 PM   #3
Sorry for the stupid question...I only know enough to change a light, but have never changed a switch (or done anything else electrical). Which would you recommend testing first? If I swap the switch and that doesn't fix it, how does one test for a loose connection...? that sounds like it could be anywhere in the conduit, yes?
Old 11-20-2012, 05:53 PM   #4
joed's Avatar
Rewards Points: 12,904
Open the switch that was worked on and inspect it.
Old 11-20-2012, 06:14 PM   #5
Will do, thank you
I'm nervous! But have all weekend to mess around with it and a book (with pictures and everything) of how electrical stuff is supposed to look. So, time to pull out the volt/amp meter and go to town lol!
thanks
VERY EERIE! Remote garge door openers and both car remotes stopped working! proofer Automotive Repairs 16 12-03-2016 08:31 AM
3 way switch layout has me confused crescere Electrical 5 09-08-2012 10:26 AM
Circuit stopped working, breaker did not trip nr5667 Electrical 7 07-08-2012 03:31 AM
Coaxial Jack STOPPED working? JayNYOne Electrical 4 12-11-2011 10:20 AM
4 way switch confusion Richo Electrical 10 04-09-2009 07:11 AM
