-   -   3 way switch to split receptacle (http://www.diychatroom.com/f18/3-way-switch-split-receptacle-152160/)
Jrhenry24 07-31-2012 05:49 PM
Hi, i am wiring a three way switch to a split receptacle. The order of the circuit is power to switch one to switch two to split receptacle outlets. I have 12/2 from power to the first switch. I have 12/3 from switch two to the outlet. Due to drywall issues my only option is running cable from swtch one to switch two. I need a 12/4 cable but it is not sold around here under 250'. Will it be okay for me to use two 12/2 cables. One for the traveler wires without a neutral and one for the neutral and hot to the always hot half of the split receptacle?
Nolfinuer 07-31-2012 05:57 PM
a blueprint would be nice if you can supply one
Jrhenry24 07-31-2012 06:04 PM
Power to switch one to switch two to outlet one split receptacle bottom half switched. Cables all must be run in that order only. Already have power to switch one and 12/3 cable from switch two to outlet one. Need 12/4 from switch one to switch two but its not sold in fifty foot lengths. Is it acceptable to use two 12/2 cables or is it necessary for safety to run one 12/2 and one 12/3?
stickboy1375 07-31-2012 06:12 PM
12 Attachment(s)
Yes, you can use two 12-2's for what you described. It will create a EMF though, but it is legal. And this is how I would do it if I didnt have any 12-4 on the truck.
Jrhenry24 07-31-2012 06:23 PM
Thank you stickboy
stickboy1375 07-31-2012 06:26 PM
12 Attachment(s)
Originally Posted by Jrhenry24 (Post 978574)
Thank you stickboy
:thumbup:
k_buz 07-31-2012 06:52 PM
Feed power to switch 2 instead of switch 1.
MisterZ 07-31-2012 06:53 PM
you're using 12AWG wire, so keep in mind box capacity.
using plastic boxes on this set up you will have about 8 conductors in box #1
i dont recall if wire nuts are counted as 1
what size box would you recommend Stickboy?? 22 cu. in. or larger??
stickboy1375 07-31-2012 06:54 PM
12 Attachment(s)
Im leading to believe power is already at switch 1? Not sure though.
stickboy1375 07-31-2012 06:59 PM
12 Attachment(s)
Wire nuts are not counted, He will need a 22.5 cu. in. for box 1 and box 2....
That would be a deep 1 gang box, but I would vote for a 4" square with a mudring if the drywall was open.
rjniles 07-31-2012 07:04 PM
The OP has not told his location. CEC IN Canada does count wire nuts.
stickboy1375 07-31-2012 07:14 PM
12 Attachment(s)
Valid point, I did not know such sillyness existed. :)
But here is the US version. :)
http://www.mikeholt.com/onlinetraini...00285381_2.jpg
Jrhenry24 07-31-2012 10:57 PM
Yes power is already to switch one from original wiring. Hvac runs directly under switch two and power is from the basement. I have an 18 cubic inch box in switch two. The original electrician from the 70s had a california three way with one lose unsheathed hot wire between switches and outlet four had (3)12/3 wires plus an outlet in an 18 cu inch metal box. Drywall is knockdown texture and hard to match unless i redid the entire wall.
Jrhenry24 07-31-2012 10:59 PM
Switch one is approximately 36 cu in double gang. There is an additional light switch and 12/2 to the light there.
