3 Way Switch And Single Pole Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 11-12-2012, 12:44 PM   #1
Rewards Points: 77
3 way switch and single pole switch
I wired a 3 way switch and single pole switch in same box, 3 way switch is fine, but i used what i thought was an always hot wire to wire up a swtich for an outside light, not thinking that the wires from the 3 way switch are sometimes hot sometimes not depending on switches position.
So the outside light only works when the 3 way switch is in certain positions. i can only guess to run another cable from another source to power the outside light. Is this my only solution?
The power comes from the far 3 way switch, 12-3 cable goes to the box that i have in question and 12-2 leaves to power the 2 lights. Then i have a 12-2 going out to the outside light.
bryan1282 is offline   Reply With Quote
Old 11-12-2012, 12:53 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 554
You are correct.
If you have close by receptacle you can tap into that to power the light.
Old 11-12-2012, 12:58 PM   #3
Rewards Points: 77
damn lol ok. i cant believe i did that. oh well.
Wiring to Replace Timer Switch with Single Pole Switch BusterT Electrical 2 10-26-2012 03:39 PM
Help with single pole switch that has me baffled NABRIL Electrical 19 03-12-2012 05:37 AM
Powering a new single pole switch off of an existing three way switch set? jamesm067 Electrical 3 01-17-2012 07:36 AM
Changing A Double Switch to a single pole switch and a dimmer switch loydbrahn Electrical 0 11-08-2011 11:00 PM
single gang single pole switch on fan fabian Electrical 14 03-05-2009 01:11 AM
