3 Way Switch To Single Pole Switch - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-30-2012, 10:59 PM   #16
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
There are reasons I suggested to just leave it other than being lazy and not wanting to respond to your specific questions.
One I mentioned in my first post...you cannot bury an electrical box. Now since you explained further, if you change the box from a 2G to a single gang, there is a good chance there will be too many wires in the box...ie the wirefill will exceed the box's rated capacity.
Old 06-30-2012, 11:14 PM   #17
DIY staff
Rewards Points: 7,174
I'm watching this---
Old 07-01-2012, 08:55 AM   #18
Burying a box
Thank you K_BUZ for your coments. I never planned on burying the box, but i didn't hink that it may have to many wires. I still need to rid myself of the one switch so I will have room for my new kitchen counters. I can move the preexisting 3 pole into a single covered box and leave it behind the cabnet and have a new switch that I wil continue to use. Do you know how I can disconect the switch and continue to use the other existing switch? Thanks
ColdYeti is offline   Reply With Quote
Old 07-01-2012, 09:23 AM   #19
DIY staff
Post a picture of the wiring in both boxes--
That will be helpful --you may be lucky and find that the entire circuit is not needed---we will see---Mike---
Old 07-01-2012, 10:30 PM   #20
First pic I want to keep. Second pic I would like to remove the 3 pole with red wire. I would like to only be able to turn on the light with the switch in the first pic. I assumed I could connect the wires in pic 2 and then put it all in a single box with the remaining switch. Hope this helps. Thanks
3 way switch to single pole switch-img_2104.jpg   3 way switch to single pole switch-img_2106.jpg
Old 07-02-2012, 06:24 AM   #21
Rewards Points: 2,516
Take out the switch you want to remove. Detach all wires to it but recall which wire goes to which terminal.
Take the wire that went to the common terminal---the black screw.
Connect this wire with either one of the other wires from the switch.
Put a wire nut on the remaining wire.
The other switch will now function as a single pole switch.
The colors of the wires in the following diagrams may not correspond to your setup. Ground is not shown for clarity.
3 way switch to single pole switch-3-way-power-into-light.jpg   3 way switch to single pole switch-3-way-power-into-light-switch-removed.jpg
hammerlane is offline   Reply With Quote
Old 07-02-2012, 11:14 AM   #22
Hammerlane is a Genius
Hammerlane you are a ...Genius! Thanks so much for the diagram. Everything is working great. Thanks for everything!
Convert three way switch setup to a single pole Casey9004 Electrical 13 05-31-2012 08:46 PM
single pole switch with pilot light tsc2011 Electrical 8 11-29-2011 07:50 AM
Single Pole Light Switch with 4 Wires dmwiecz Electrical 6 11-22-2010 06:41 PM
single gang single pole switch on fan fabian Electrical 14 03-05-2009 01:11 AM
Help with single pole switch ballutster Electrical 2 10-13-2008 07:57 PM
