3 Way Switch To Single Pole Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 06-29-2012, 01:34 PM   #1
3 way switch to single pole switch
I have dual light switches that are 12 feet away from each other. This is totally useless. I would like to make just one switch and remove/block off the other switch. I am not sure which wires to tie together for this. Each switch has a red, white, and black wire to each 3 way switch. Any help is greatly appreciated. Thanks
ColdYeti is offline   Reply With Quote
Old 06-29-2012, 05:42 PM   #2
An old Tradesmen
Rewards Points: 6,560
Moved to Electrical forum.
Old 06-29-2012, 06:05 PM   #3
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
Look at each switch and there should be a screw that has a different color than the other 2 or is marked common, let us know what colors are on those.
wirenut1110 is offline   Reply With Quote
Old 06-29-2012, 08:42 PM   #4
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
If its useless...don't use it. You cannot just patch over an electrical box, so you will still have a blank plate on the wall.
Old 06-29-2012, 09:59 PM   #5
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
I agree, not sure why people feel the need to remove a switch they simply don't use.
Old 06-30-2012, 02:35 PM   #6
I purchased new Kitchen cabinets. One of the 3 way switches that is useless is right in the way of the edge of the cabinet. Since I do not use the 3 way switch that is in the double box I can change it to a single box, therefore making room for my cabinet. I didn't feel I needed to explain all of this. I just wanted to know how to disasemble the one 3 way switch and I wiull take care of the rest. If what you are posting has no value to the thread then do not post. I dont care about YOUR opinion. Thanks for those that want to help.
Old 06-30-2012, 02:42 PM   #7
Rewards Points: 2,516
Is the switch you want to do away with at an entrance way/doorway to the kitchen
hammerlane is offline   Reply With Quote
Old 06-30-2012, 02:46 PM   #8
Box "1" that I don't want the switch in.
Top Right silver screw red wire, Top Left Silver screw White wire, Bottom Right Black screw Black Wire.
Box "2" Keeping switch
Top Left Black Screw Black Wire, Bottom Left Silver Screw White Wire, Bottom Right Silver Screw Red Wire.
Hope this makes sense. Thank you for your help.
Old 06-30-2012, 02:48 PM   #9
No the one I am keeping is though.
Old 06-30-2012, 04:34 PM   #10
Rewards Points: 166
have a good day
Minus08 is offline   Reply With Quote
Old 06-30-2012, 06:43 PM   #11
E2 Electrician
You have no idea why we ask the questions we ask, we try to respond with the most accurate info given, so what if a thought is said aloud, I don't know what it is your doing, I'm not a mind reader and don't what to be one, but I can tell you all the fun stuff I've come across...
Old 06-30-2012, 06:56 PM   #12
DIY staff
Rewards Points: 7,174
You came to a group of helpful electricians on their day off---and demanded an answer--right now--without any friendly chatter--
then rudely insult a man with the knowledge you lack--
Is your life always this way? Do you not have a moment to chat with the stranger that you ask for help?
---Mike----
Evstarr (07-01-2012)
Old 06-30-2012, 07:47 PM   #13
The Following User Says Thank You to hammerlane For This Useful Post:
oh'mike (06-30-2012)
Old 06-30-2012, 11:15 PM   #14
Insult?
I in no way insulted anybody. I was told by 2 individuals that knew nothing about the situation and in no way were trying to help, leave messages that were completly useless. Maybe you should go back and reread the entire post. To those that were being helpful I gave my full attention. To those who's suggestion was "just dont use the switch..." I think I could have figured that one out on my own. I do not need to file through useless posts trying to find the answer to the problem that I am facing. I have thanked those willing to help and have asked those that are not helpful to not post. If you feel insulted than I appologise, bgut really I just want to find thecorrect answer and not be told the answer is just dont use the switch, and not sure why people feel the need to remove a switch they simply don't use. To stickboy you have not asked a question, so your post that I do not understand the questions you ask. Ihave answered all questions asked. If someone has an answer to the original post I would love to hear it. To "Oh' Mike" If you are a senior moderator I invite you to look up my phone or personal email. I would love to talk to you to see why you replied the way you did, perhapse you did not understand my email. Thank you for your time.
Old 06-30-2012, 11:32 PM   #15
jbfan's Avatar
Rewards Points: 254
What other connections are in the box you want to elimate?
Code does not allow you to hide connections behind a cabinet.
Convert three way switch setup to a single pole Casey9004 Electrical 13 05-31-2012 09:46 PM
single pole switch with pilot light tsc2011 Electrical 8 11-29-2011 08:50 AM
Single Pole Light Switch with 4 Wires dmwiecz Electrical 6 11-22-2010 07:41 PM
single gang single pole switch on fan fabian Electrical 14 03-05-2009 02:11 AM
Help with single pole switch ballutster Electrical 2 10-13-2008 08:57 PM
