Old 09-14-2012, 11:28 AM   #1
Unhappy
3 way switch (shocked)
Ok so I wanted to redo my kitchen because my wife hate the old one, so i riped all the cabnits out and replaced the drywall. Then i ran into something the internet is calling a 3 way switch. Well i read on how it work and wired it back up but each time i turn the switch on it popes the breaker. any and all help would be nice. It has a Red Wire if that means any thing.
also been shocked 2 times now
Joel
rcimemphis is offline   Reply With Quote
Old 09-14-2012, 11:38 AM   #2
obviously it isn't wired like it was before you removed it. we can't see it from here, pictures are very helpful. for future reference take photos before disconnecting things and never take apart more then you have to. is there more than just a red wire?
Old 09-14-2012, 12:12 PM   #3
Yes im sorry new to this
There are 2 black ones and 1 red one. Also this home was built in 1979 so all the wiring has been mest up. someone went in and added lights and one of the switches is set to + and the other is -
Old 09-14-2012, 12:22 PM   #4
Resi EC
So the red wire is tied to the common on the 3-way switch (darker screw)
and the 2 black wires are tied to the brass colored screws?
edit: Were all three wires used on old switch?
Do you have a way to test voltage?
Gac66610 is offline   Reply With Quote
Old 09-14-2012, 01:05 PM   #5
The internet is not calling it a 3-way switch. It is a 3-way switch.
You did not understand how it works if when you wired it back up it "popes" the breaker"
hammerlane is offline   Reply With Quote
Old 09-14-2012, 01:11 PM   #6
Joel with
If you are going to promote your company, at least read your post so as to check for some spelling errors.
Old 09-14-2012, 02:39 PM   #7
joed's Avatar
There has to be more than three wires in the box. With only three wires there no way to hook it up so it pops the breaker. Tell us all the wires and maybe we can spot the problem.
Do not PM with questions that can be asked in a forum. I will not respond.
Old 09-14-2012, 03:37 PM   #8
An old Tradesmen
Why are you asking here, when your companies website says your company does wiring?
Old 09-14-2012, 04:59 PM   #9
Master Electrician
I suspect its a three way switch being used as a single pole and a second circuit passing through the box.
Also curious as to how you do restoration and don't know what a three way is. Almost every handyman knows a threeway switch even if they can't wire them. I suspect more to the story here.
Also wondering why your working on it live and getting zapped. Then you somehow thought that was a good idea and did it a second time.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Old 09-14-2012, 05:29 PM   #10
Old 09-14-2012, 07:17 PM   #11
the Musigician
DangerMouse's Avatar
Looks like trolling spam to me....
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
Tags
3 way, breaker, kitchen, memphis, water
Wiring in a 4-way Switch RickSene Electrical 5 04-09-2013 08:25 PM
Generator Transfer Switch Trouble wgramer Electrical 23 11-12-2011 08:23 PM
Changing A Double Switch to a single pole switch and a dimmer switch loydbrahn Electrical 0 11-09-2011 12:00 AM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 07:43 PM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 02:24 AM
