3 Way Switch Replacement - Electrical - DIY Chatroom Home Improvement Forum
Old 07-24-2010, 01:55 PM   #1
3 way switch replacement
Hello. I'm replacing a 3 way wall switch and need some help figuring out how to wire it. Unfortunately, I don't have the original switch but I got a replacement that I think should work. It has 2 terminals on one side (one marked common,) and one terminal on the other side.
Out of the wall, there are 3 black wires and one whilte wire. I know the hot wire goes to common but I'm not sure what to do with the other 3 wires. I checked the other switch that controls the light and it only has 2 black wires and 1 white wire!? So, I can't copy what was done on it because the switch I'm working on has an additional black wire.
Can someone help with this?
Thanks!
raptor123 is offline   Reply With Quote
Old 07-24-2010, 02:08 PM   #2
Electrician
Proby's Avatar
Do you happen to have the ability to take and post a picture of this box?
Proby is offline   Reply With Quote
Old 07-24-2010, 02:20 PM   #3
Here are two pics. The one of the switch is the NEW switch. I have it currenly wired as shown and I forgot one thing that might be important. It actually works the way it's wired now, but ONLY if the other switch is turned on. Otherwise, flipping the swtich does nothing.
Old 07-24-2010, 11:25 PM   #4
Electrician
Rewards Points: 802
Can't help you solve the problem you orginally asked, next time you should mark the wires before takeing them off the switch.
Couple things i noticed in the picture though, the way you have the white wire is not correct, that wire should be bent and put on the screw in a clockwise direction and then tighten down. It also looks like you may have backstabbed the other connections, nothing in code says you can't do it but i have heard more problems about those then good things.
darren is offline   Reply With Quote
Old 07-25-2010, 12:26 PM   #5
joed's Avatar
Rewards Points: 13,712
What about the rest of the wires in the box. If you have two blacks you should have two whites.
Your description of the operation indicates the wrong wire is on the common.
Old 07-25-2010, 12:35 PM   #6
Electrician
Proby's Avatar
It seems as if instead of running a 3-wire they ran (2) 2-wires (which is against code in this situation). Usually they would cap one of the wires off. Open up the other switchbox and see if any wire is not being used.
I agree with darren, you really have to mark the wires (or take pictures) before taking apart older devices.
Old 07-25-2010, 02:31 PM   #7
Electrical Contractor
kbsparky's Avatar
Try installing the (2) black wires from the right side both on the "common" terminal; connect the remaining white and black wires on the other 2 terminals ....
-KB
Old 07-25-2010, 06:20 PM   #8
Does it matter which terminals the white and black go to?
Old 07-25-2010, 06:26 PM   #9
Electrician
Proby's Avatar
Nope.
Old 07-25-2010, 06:43 PM   #10
That worked! Thanks very much.
Condenser Fan Cycling Switch Replacement wirenut1110 HVAC 2 01-23-2010 09:29 AM
HowTo: Adding two exterior lights + switch, piggyback new switch off existing switch? ghost Electrical 14 04-19-2009 05:04 PM
Hunter Fan Dual Switch Wiring Configuration Help schierle Electrical 2 03-29-2009 08:00 PM
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 06:14 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
