3 Way Switch Randomly Does Not Work - Electrical - DIY Chatroom Home Improvement Forum
Old 06-25-2012, 12:05 AM   #1
Rewards Points: 111
3 way switch randomly does not work
hey all,
I have a 3 way switch circuit to the hallways. There are two 3 way switchs controlling the hallway lights. Recently, it started being intermittent. The switches are practically new. I replaced the old ones several months ago.
suncowiam is offline   Reply With Quote
Old 06-25-2012, 12:08 AM   #2
So you turned the breaker off, pulled off the cover, checked your connections, and it still does this?
CopperClad is offline   Reply With Quote
Old 06-25-2012, 06:50 AM   #3
Rewards Points: 1,418
Wire ends held on or held in using screws make much more reliable connections than wires just pushed into the backs of switches, receptacles, etc. and seem to stick in place.
Although we cannot rule out a wire breaking unseen inside the black or white covering, if that were the cause then it requires a lot of busywork testing to find.
Step 2 consists of turning off the power, unhooking at least one end of the suspected wire from the switch or light or receptacle, clipping one lead of a meter set to continuity/ohms testing to that end, and clipping the other lead to the other end, using a long length of wire stretched across the floor in between if needed.
(Step 1 consists of finding the other end of the wire you are about to test.)
The above is not that complicated, but is arduous enough to make you want to check for other reasons firs.
Old 06-25-2012, 06:53 AM   #4
DIY staff
Rewards Points: 7,174
Don't over look the possibility that one of the new switches might be junk---It happens.
CopperClad (06-25-2012)
Old 06-25-2012, 08:52 AM   #5
Licensed electrician
Rewards Points: 1,028
Is this a case where if one switch is in a certain position the other does not work? If so you have mis-wired a switch.
Old 06-25-2012, 05:00 PM   #6
Rewards Points: 111
when i initially replaced, it was working fine from both switches.
it start intermittently working several days ago and stopped working alltogether. but only if i have it set to a specific configuration...:
A:
first switch can switch fine when second switch is turned off (down). second switch will sometimes turn on but immediately off when switched up.
Maybe a loose connection. I'll have to verify.
Old 06-25-2012, 06:56 PM   #7
joed's Avatar
Rewards Points: 11,588
Sounds like a loose connection, probably in the second switch. If you are using the push in connection move the wires to the screw terminals.
two switch ceiling fan/ light question ifthenelsenull Electrical 4 12-29-2011 04:23 PM
3 way switch -OK to drop down neutral like this to light through switch box via 12/3? darlingm Electrical 9 12-22-2011 03:48 PM
short circuit. reset the breaker, but no power bp91708 Electrical 10 03-18-2011 11:07 AM
installed recessed lights but now switch does not work auggie77 Electrical 2 08-02-2009 11:11 AM
single gang single pole switch on fan fabian Electrical 14 03-05-2009 02:11 AM
