3 Way Switch Question - Electrical - DIY Chatroom Home Improvement Forum
Old 03-24-2010, 08:58 AM   #1
Rewards Points: 93
3 way switch question
I have a three-way switch lighting a light on a staircase. Switch at the top and bottom of the stairs. I had it disconnected. I believe that it was originally powered from another switch in the same box located at the bottom of the stairs. I am re-wiring and trying to figure out how to wire it back up. Currently this is what I have, the three way switch at the bottom of the stairs that shares a box with a switch that lights another room (this is where I believe I was getting power from), I then have a 14/3 run up to the switch at the top of the stairs, from there I have a 14/3 run to the light above the stairs that lights the stairs. What is the correct way to wire the three-way from the power on the downstairs switch and control the light from both locations? Drawing a blank. Thanks
bfan781 is offline   Reply With Quote
Old 03-24-2010, 09:30 AM   #2
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
If incoming power is in the downstairs light switch box connect the incoming power (Hot) to the common of the downstairs 3-way. Then a 14/3wg to the upstairs switch then a 14/2wg to the light. Make it look like this ... you may have to use a pigtail since two switches are sharing the incoming power hot. All the whites in a wirenut by themselves and and grounds in a wirenut by themselves with pigtails to the switch ground screw and to the metal box if it is metal.
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 03-24-2010, 10:39 AM   #3
Rewards Points: 93
thanks stubbie for the diagram it makes it easier to visualize. So since there is another switch in downstairs box, next to the three-way, that is where I am going to get power from. The hot is going to have to be pigtailed going to the regular switch and then to the common on the three-way?
Old 03-24-2010, 11:05 AM   #4
UAW SKILLED TRADES
Stubbie's Avatar
Yes your going to take the incoming hot wire, one wirenut and two pigtails about 5 inches long and connect all three in the wire nut then connect one pigtail to the single pole switch and one to the 3 way switch common screw (dark colored one) then just follow the diagram.
Stubbie
Old 03-24-2010, 11:57 AM   #5
Rewards Points: 93
Gotcha! Thanks again
3 way switch question brons2 Electrical 11 03-08-2010 01:58 PM
Dimmer Switch Question Livewire78 Electrical 6 01-03-2010 09:51 PM
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 03:06 PM
Another 3-way switch question. perpetual98 Electrical 10 07-21-2009 11:16 AM
4 way switch confusion Richo Electrical 10 04-09-2009 07:11 AM
