3 Way Switch Question - Electrical - DIY Chatroom Home Improvement Forum
Old 03-07-2010, 09:59 PM   #1
E-lec-tri-city
Rewards Points: 150
Send a message via ICQ to brons2 Send a message via AIM to brons2 Send a message via MSN to brons2 Send a message via Yahoo to brons2
3 way switch question
I want to set up a 3 way switch circuit with the light wired between the two switches. The power will come into switch box #1 via 12/2 then there will be a 12/3 over to the light and a 12/3 from the light to the other switch in switch box #2. This much I have schematics for already, so I am confident I can do this part.
However...
Is it possible to carry non-switched power for other purposes from the 2nd switch in the scenario described above? In this case I want to power another non-3 way switch circuit in switch box #2.
brons2 is offline   Reply With Quote
Old 03-07-2010, 10:10 PM   #2
Master Electrician
Rewards Points: 3,920
Not possible.
brric is offline   Reply With Quote
Old 03-07-2010, 10:19 PM   #3
joed's Avatar
Rewards Points: 13,354
Not possible unless you use 12/4 cable. You don't have a neutral in the second switch box.
Old 03-07-2010, 10:40 PM   #4
" Euro " electrician
frenchelectrican's Avatar
Not possible with this combation unless you snag up a oddball 12-4 NM cable I do not know if that is avaibale in your area.
Otherwise a electrical supply centre is best bet to have this stocked up or order one but a nice gotcha is with oddball size you may not get this in footage you may end up get a full coil { 250 footer }
Merci. Marc
Last edited by frenchelectrican; 03-07-2010 at 11:17 PM. Reason: fix my goof due my mind crossed between metric and standard AWG size
Old 03-07-2010, 10:58 PM   #5
E-lec-tri-city
Rewards Points: 150
I've never seen a 12/4 cable, so I guess that answers that question.
I do have a Border States electrical supply house nearby and they are pretty friendly, their hours just aren't as convenient as Home Depot. But out of curiosity I will ask them if they carry 12/4.
Old 03-07-2010, 10:59 PM   #6
Rewards Points: 1,542
Run an additional 2 wire cable from the power feed (in switch box #1) to switch box #2. This does not go through the light box but may pass the outside of the light box if that is the easiers route.
Old 03-07-2010, 11:27 PM   #7
Allen have one good way to do this and that will keep the cost down a little but let me warn ya when you go from switch box to other switch box make a note which one is legit netural and non netural white conductor that used on three way switch { that part you have to make a note of connections }
BTW let me add this part there is two verison of 12-4 NM it will be either 12-2-2 NM or 12-4 NM both look the same but the colour of each conductors are diffrent the 12-2-2 is black , white , red , white with red stripe or the 12-4 verison will be Black , Red , Bleu and white conductors colours so keep in your mind it will go either way.
Merci,Marc
Old 03-08-2010, 06:29 AM   #8
Master Electrician
You say you want to set this up. IF YOU CAN GET A 12/3 between the switch boxes, I see no reason you cannot get an additional 12/2 between the same two boxes to carry power over.
Old 03-08-2010, 07:36 AM   #9
Licensed electrician
Rewards Points: 1,788
I think it would be easier just to bypass the light fixture box and just run the power from switch one to the other location.
Old 03-08-2010, 08:20 AM   #10
E-lec-tri-city
Rewards Points: 150
Yes, I can easily get an additional 12/2 between the switch boxes to carry the power, just trying to save some copper if possible. I guess it isn't, so I'll just extend the power with another 12/2.
Old 03-08-2010, 09:19 AM   #11
Master Electrician
Best solution. Well done.
Old 03-08-2010, 01:58 PM   #12
Just noticed that with
power -- switch #1 -- light -- switch #2
you need five conductors to have both three way and continuation beyond switch #2 since with 3 conductors switch #2 has neither unswitched hot nor neutral reaching it.
Dimmer Switch Question Livewire78 Electrical 6 01-03-2010 09:51 PM
Light switch installation problems pc_clone Electrical 8 11-30-2009 09:25 PM
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 03:06 PM
Another 3-way switch question. perpetual98 Electrical 10 07-21-2009 11:16 AM
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 06:14 PM
