3 Way Switch Question - Electrical - DIY Chatroom Home Improvement Forum
Old 10-06-2009, 07:38 PM   #1
3 way switch question
quick question i hope!
I have a light that is controlled by two 3-way switches.
i have everything hooked up correctly for the two 3-way switches to work, the problem im having is that the circuit continues to another light from the light that is hooked to the 3-way switches, i need to know how to keep constant power to the other light.
theBuilder is offline   Reply With Quote
Old 10-06-2009, 08:03 PM   #2
You obviously need to feed that light fron a source of constant power.
Is there constant power in the light box it is fed from or is it just the switch leg in there?
You may have to feed it from a switch box or receptacle box.
220/221 is offline   Reply With Quote
Old 10-06-2009, 08:13 PM   #3
constant power comes in box to 3-way, then goes to light, then another 3-way goes to the light, and the circuit i need to tie into is in the light box as well
Old 10-06-2009, 08:21 PM   #4
Too vague. No patience for 50 questions.
Describe the cable type and route.
2 wire cable = black and white.
3 wire cable = black red and white.
Ignore the bare ground for this discussion
Use the terms switch one and switch two for the two 3 way switch locations.
Old 10-06-2009, 08:36 PM   #5
i have a 2 wire cable for constant power coming into switch one, the white constant connected to white going to light, black constant connected to switch, black and red connected to switch going to light, the white wire is connected to light, the black wire is connected to (3 wire cable)white wire going to switch two, red is travel wire from switch one to switch two, and the black wire from switch two is connected to light. i hope this is not too confusing
Old 10-06-2009, 08:53 PM   #6
OK...focus.
You started off great but quickly digressed.
Describe the cable type and entire route. Forget the wiring connections for now.
Old 10-06-2009, 08:55 PM   #7
2 wire constant into switch one, from switch one 3 wire cable to light, 3 wire cable from light to switch two, 2 wire cable from light to another circuit
Old 10-06-2009, 09:05 PM   #8
THERE you go
You don't have a hot in switch #2 (one wire short)
You need to feed the "other circuit" from switch one instead of switch #2
edit. Actually that's all jacked up. I don't see how it can even work the one light properly?
Are the walls still open?
Old 10-06-2009, 09:07 PM   #9
but the other circuit is in the light box, do i need to move the wire from the light to switch one or another power source?
the light works fine the way it is
Old 10-06-2009, 09:25 PM   #10
Crap.....again I am having trouble with your terminology. The only "power source" you have now is in switch #1.
You have
The way I read it, "another circuit" is actually "another light" that for some reason needs constant power (pullchain?)
Also, you said that the 3 ways worked but I can't see how.
This would be a standard method of wiring
3 wire cable from switch one to switch two.
2 wire cable from either switch to light
2 wire cable from switch one to "another circuit/another light that needs constant power"
Old 10-06-2009, 09:33 PM   #11
well this was a bathroom that we are renovating, and the power to part of the house gets its power from the light in the bathroom
your method is right except i have a switch on either side of the light, and the "other circuit" is just going to the adjacent room and bathroom to supply them power
I have the light and switches hooked up exactly as you should with a switch/light/switch hookup, i just can't figure out which wires to get my continuous power from out of the light box to go to the rest of the house
Old 10-06-2009, 09:34 PM   #12
I see how the 3way is working. It is unothodox (in my area anyway) but it works.
The only constant power you have is in switch #1 so you will have to feed your other bathroom light from switch #1 or some other source. There is no hot or neutral in sw #2 and no hot in the light box.
Old 10-06-2009, 09:36 PM   #13
ok, well i'll work on that, i appreciate your help, ha, yeah i guess it wasn't such a quick question. thanks again
Old 10-06-2009, 09:58 PM   #14
I believe this drawing is what you have the brown wire in the drawing is what is missing.
hayewe farm is offline   Reply With Quote
Old 10-06-2009, 10:29 PM   #15
joed's Avatar
Rewards Points: 11,632
You do not have a constant hot at the light. You only have neutral and switched hot and two traveler wires. If you want to power your second light from the first light then you need a fourth wire from switch one to the fixture.
You should pull power for the second light from the first switch with the power cable.
Another 3-way switch question. perpetual98 Electrical 10 07-21-2009 12:16 PM
Motion switch wired to two circuits Sibkuz Electrical 2 04-22-2009 08:31 PM
4 way switch confusion Richo Electrical 10 04-09-2009 08:11 AM
Beginner Question - Residental Switch willedon Electrical 6 03-31-2008 09:12 PM
changing a fixture to an outlet - keeping the switch aweshucks Electrical 4 12-27-2007 06:06 PM
