Old 10-05-2008, 04:47 PM   #1
3 way switch question
I replaced the switches in our new house and now the three way switches do not work properly in the room. Only one switch (A) turns the light on/off but only when the other switch (B) is flipped on. If I flip B off, then A does not work at all. How do I figure this out? Any help is appreciated.
FYI, I have two black wires and a white wire coming out of each box. Right now I the white wire hooked up to the off-color screw in each box.
Wittsmall is offline   Reply With Quote
Old 10-05-2008, 05:45 PM   #2
dSilanskas's Avatar
Oh boy sounds like you might have a junction box somewhere haha and You should have a black, white, and red in each box. So try hooking the black wire up to the common screw or the black screw.
dSilanskas is offline   Reply With Quote
Old 10-05-2008, 05:53 PM   #3
Just keep guessing eventually you'll get it right.
There are many ways to install 3 way wiring. I am guessing that one of the blacks is common.
Without a tester, it's a guessing game.
Is one of the black wires in a different cable than the others? If so, it will likeley be the common.
More discription please. look in the box and see which wires go to which cables. (a cable consists of multiple wires)
220/221 is offline   Reply With Quote
old wire, backfed switch question Jack A. Trades Electrical 6 07-03-2008 12:05 PM
Simple wall switch question LZCenter Electrical 8 06-30-2008 11:01 AM
Switch question gelert Electrical 1 12-22-2007 09:06 PM
3-Way Switch Wiring Question bhpizza Electrical 4 08-07-2007 06:51 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 02:19 AM
