3 Way Switch Question - Electrical - DIY Chatroom Home Improvement Forum
Old 09-24-2013, 06:54 PM   #1
3 way switch question
I already have a 3 way switching installed to just one light. The power (hot ) comes into the first 3 way switch ( in the basement ) and from there the 3 way wire runs to the 3 way switch at the top of the stairs. From that switch runs 2/12 leg wire to the light. What I would like to do if possible is install another light in the basement off of this setup. I can not feed a line from the light to the one I want to install nor can I feed a line from the top stairs 3 way switch to the new light. Is there any way to come off of the first 3 way (power) switch to the new light and have both switches operate that new light?
oldsage is offline   Reply With Quote
Old 09-24-2013, 06:58 PM   #2
MarginallyQualified
Rewards Points: 2,464
Tie into the switched circuit (the 2wire) either at the light fixture or at the second switch.
I can not feed a line from the light ... nor can I feed a line from the top stairs 3 way switch to the new light.
Those are still your choices.
Next up is digging into walls and ceilings.
Old 09-24-2013, 07:10 PM   #3
So what you are saying is " that the dog won't hunt". No can do without running from top switch or light.
Old 09-24-2013, 09:00 PM   #4
joed's Avatar
Rewards Points: 12,854
Then you can't add another light to the switch.
Old 09-25-2013, 07:16 AM   #5
Electrical Contractor
jbfan's Avatar
Rewards Points: 474
You can add a new switch at #1 and power just the new light.
jbfan is online now   Reply With Quote
Tags
3 way switches 2 lights , electical wiring
3-way switch wiring question brightlight Electrical 8 12-30-2014 05:50 PM
Changing A Double Switch to a single pole switch and a dimmer switch loydbrahn Electrical 0 11-08-2011 11:00 PM
fan/light switch buzzing mjlocat Electrical 4 05-23-2010 02:44 PM
3 way switch question brons2 Electrical 11 03-08-2010 01:58 PM
Another 3-way switch question. perpetual98 Electrical 10 07-21-2009 11:16 AM
