-   -   3 way switch question (http://www.diychatroom.com/f18/3-way-switch-question-187591/)
oldsage 09-24-2013 06:54 PM
I already have a 3 way switching installed to just one light. The power (hot ) comes into the first 3 way switch ( in the basement ) and from there the 3 way wire runs to the 3 way switch at the top of the stairs. From that switch runs 2/12 leg wire to the light. What I would like to do if possible is install another light in the basement off of this setup. I can not feed a line from the light to the one I want to install nor can I feed a line from the top stairs 3 way switch to the new light. Is there any way to come off of the first 3 way (power) switch to the new light and have both switches operate that new light?
TarheelTerp 09-24-2013 06:58 PM
Tie into the switched circuit (the 2wire) either at the light fixture or at the second switch.
I can not feed a line from the light ... nor can I feed a line from the top stairs 3 way switch to the new light.
Those are still your choices.
Next up is digging into walls and ceilings.
oldsage 09-24-2013 07:10 PM
So what you are saying is " that the dog won't hunt". No can do without running from top switch or light.
joed 09-24-2013 09:00 PM
Then you can't add another light to the switch.
jbfan 09-25-2013 07:16 AM
You can add a new switch at #1 and power just the new light.
