3 Way Switch Problem - Electrical - DIY Chatroom Home Improvement Forum
Old 12-06-2010, 05:31 PM   #1
3 way switch problem
I recently attempted to install a dome light above my entrance door (inside). I attempted to splice into the traveling wire(black white copper red) within the loop of a 3 way switch and dropped this line to the light box. I have two switches and a light upstairs that were already installed. Now only the top light comes on when i flip the switch on and both lights come on but flicker when i flip the switch off. Is there any way to wire this or did I completely screw it up? Thanks for the help.
fabes411 is offline   Reply With Quote
Old 12-06-2010, 05:40 PM   #2
not really enough info to go on, but it probably won't work. You need to find the common feed the the lights. no 3way switches are ever wired the same, there are some common ways, but it all depends on where the live feed is, where the load wires are, and how the travellers are ran. You should turn off power (at the fuse panel) and find out what and how many wires are in the switch boxes and the existing light. Then someone can maybe help you out.
dhubz is offline   Reply With Quote
Old 12-06-2010, 05:46 PM   #3
traveler wire
yeah i think im pretty much up the creek here. but what i was getting at is, i spliced into the traveler wire and dropped that to the new light box. is there any way to wire the light now so it will work within the three way switch? or should i get the spackle out?
Old 12-06-2010, 05:46 PM   #4
Rewards Points: 150
Connect to the light
Do you have a way to run the wires from the light? if so the light should only connect to 2 wires if you can run a line from that light to your light you are attempting to connect to you will have a Series Parallel circuit and it should work
Docwhitley is offline   Reply With Quote
Old 12-06-2010, 05:51 PM   #5
Electrical Contractor
jbfan's Avatar
Rewards Points: 424
You need to get the spackle out, but you also need to be able to access the splice on the wires.
Old 12-06-2010, 05:55 PM   #6
sounds like you did a big no-no, you can't just splice into wires and leave them buried behind walls or in ceilings. please tell me you al least used a proper box with marrettes. now you have 2 issues it won't work the way it is and you have a buried junction point.
Old 12-06-2010, 06:03 PM   #7
no no the house is a cape, i got up in the crawl space and wired up a junction box (3 ways) locked up all the wired in the box and used the wire nuts to connect the 4 lines. Than dropped the unconnected line down a hole in the ceiling and locked it into a ceiling light box.
Old 12-06-2010, 06:04 PM   #8
i dont have have access to the light just to the traveler wire.
Old 12-07-2010, 07:00 AM   #9
I am with the others here. There is typically not a neutral in the traveler wire, which means you cannot splice into it for a light. While you state you don't have access to the existing light, how how easy would it be to run a wire from either of your two switches? One of the switches is the one controlling your existing light. It is possible (though not absolutely certain) that one of your switches has switch hot and neutral available.
oberkc is offline   Reply With Quote
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 06:43 PM
fan/light switch buzzing mjlocat Electrical 4 05-23-2010 02:44 PM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 01:24 AM
Problem changing light switch grgryl Electrical 14 08-10-2008 01:26 PM
3 way switch problem Rschrei518 Electrical 2 01-04-2008 12:35 AM
