3 Way Switch Problem. - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 01-02-2010, 12:10 PM   #31
Problem Fixed.
All fixed now, thanks to all for the help. And now that I had to punch a hole in the wall, the wife wants to use this opportunity to repaint the entire room.
Blade_316 is offline   Reply With Quote
Old 01-03-2010, 10:25 PM   #32
Master Electrician
richgriffith's Avatar
what kind of devices are you using? because the kinds im familiar with ether the travelers are on the same side of the switch as one another and the common on the other side by its self or there directly across from one another with the common on the bottom of the switch. because if the sketch is the way you did it. switching the white & black on switch 2 should have corrected it.
richgriffith is offline   Reply With Quote
Tags
3-way , problem , switch , wiring
Light switch installation problems pc_clone Electrical 8 11-30-2009 09:25 PM
Switched receptacle wiring problem. sheshore Electrical 6 09-27-2009 01:37 PM
Problem changing light switch grgryl Electrical 14 08-10-2008 01:26 PM
3 way switch problem Rschrei518 Electrical 2 01-04-2008 12:35 AM
combo switch problem electric1 Electrical 2 06-11-2004 10:11 AM
