3-way Switch Problem - Electrical - DIY Chatroom Home Improvement Forum
Old 06-11-2009, 11:22 AM   #1
Lightbulb
3-way switch problem
I have 3 wires running into a single gang nail up box. Two are 14-2 and a 14-3. This will be a 3-way switch. The issue i am having is normally there is only a 14-2 and a 14-3 wire in this type of box. The first 14-2 wire is going to the panel. The second 14-2 wire is going to the lights. The 14-3 wire is going to the other switch location. how can i make this work
Urfireman000 is offline   Reply With Quote
Old 06-11-2009, 11:53 AM   #2
Connect the neutrals(white) of the 2 14-2 cables.
Connect the black of the 14-2 that feeds the lights to the line/load terminal of the first 3-way.
Use a sharpie to mark the white of the 14-3 as hot (black at both ends).
Connect the re-coded white to the black wire of the 14-2 coming from the panel.
Connect the black & red wires of the 14-3 to the traveler terminals of the first 3-way.
At the second 3-way, connect the red & black conductors of the 14-3 to the traveler terminals, and the re-coded white to the line/load terminal.
Good luck,
Keith
KeithM62948 is offline   Reply With Quote
Old 06-11-2009, 12:57 PM   #3
Thanks i'll try it
Old 06-11-2009, 02:23 PM   #4
joed's Avatar
Rewards Points: 13,322
This is what you need to do.
Old 06-11-2009, 02:55 PM   #5
Although the result is the same, I always send the power to the dead ended switch on the black.
14/2 power in and 14/3 blacks together.
14/2 whites together.
Blacks to common terminals.
red/white travelers.
Sharpie smarpie
220/221 is offline   Reply With Quote
Old 06-11-2009, 06:39 PM   #6
Electrician
SD515's Avatar
Rewards Points: 504
14/2 power in and 14/3 blacks together...
Except that this is a code violation. A cable, other than the source cable, used to feed power to a switch (a switch leg), must have the power sent to the switch on the white (re-identified) and not be used as the return conductor from the switch. 200.7 (C)(2)
Kyle
Old 06-11-2009, 06:53 PM   #7
joed's Avatar
Except this is not a switch leg. The power does not go to the fixture first. The intent of that code article is not have the light connected to two white wires.
Old 06-11-2009, 07:02 PM   #8
Electrician
SD515's Avatar
Rewards Points: 504
Then let's call it a switch loop, as the code book does, and yes it is a switch loop. It doesn't have to go to the fixture first. Read the code section (not trying to be snippy, an jerk, or anything).
This I agree with.
Kyle
Old 06-11-2009, 07:07 PM   #9
joed's Avatar
2008 code has been reworded to say refering to the white
'used for the supply to the switch but not as the return conductor from the switch to the switch outlet.' Note the switched outlet part.
A switch loop/leg is power at the fixture first then to the switch and returning in the same cable. 14/3 between 3way switches is not a switch loop.
Problem changing light switch grgryl Electrical 14 08-10-2008 01:26 PM
3 way switch problem Rschrei518 Electrical 2 01-04-2008 12:35 AM
changing a fixture to an outlet - keeping the switch aweshucks Electrical 4 12-27-2007 05:06 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
combo switch problem electric1 Electrical 2 06-11-2004 10:11 AM
