3 Way Switch Problem - Electrical - DIY Chatroom Home Improvement Forum
Old 02-27-2013, 11:06 PM   #1
3 way switch problem
I have a three way switch controlling the lighting in my kitchen. The problem is when I turn the lights off at the switch by the bedroom, the other two switches wont turn the lights on; and if I turn the lights off by the other two switches, the one by the bedroom wont turn them on. Is there an easy fix for this?
cnich27 is offline   Reply With Quote
Old 02-27-2013, 11:15 PM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Wire the switch/s properly.
Old 02-28-2013, 09:18 AM   #3
joed's Avatar
Rewards Points: 12,028
Switches are mis wired. You need to get the proper wires on the common terminals.
Old 02-28-2013, 01:43 PM   #4
Rewards Points: 2,516
If you have 3 switches that controls the lights this is a 4-way setup which entails two 3-way switches and one 4-way switch. Did this stop working properly just out of the blue or did you try to change a switch or have your hands in something?
There is an easy fix for this once you understand how a 4-way switch arrangement works.
hammerlane is offline   Reply With Quote
Light Switch Problem akent215 Electrical 3 03-05-2011 03:12 PM
Ceiling Fan and Light Switch Problem desiboy Electrical 3 03-03-2011 01:09 PM
fan/light switch buzzing mjlocat Electrical 4 05-23-2010 03:44 PM
Problem changing light switch grgryl Electrical 14 08-10-2008 02:26 PM
3 way switch problem Rschrei518 Electrical 2 01-04-2008 01:35 AM
