3-way Switch - Powered Switch In Middle? - Electrical - Page 4 - DIY Chatroom Home Improvement Forum
Old 06-14-2012, 11:20 AM   #46
Rewards Points: 605
By the way, some have mentioned that this is such a common question but I don't find anything in this site or any other site on power coming in to the middle switch. Even sites with as many as 8 different scenarios don't cover this power-in-the-middle scenario.
Thanks, Code05 for the very useful switch diagram. Though I am not an electrician, I have decades of experience in electronics and the reminder that this is just a SPDT switch scenario makes it really easy to understand.
dalepres is offline   Reply With Quote
Old 06-14-2012, 11:28 AM   #47
Code05's Avatar
Rewards Points: 1,104
Are you saying you have a solution or not?
Code05 is offline   Reply With Quote
Old 06-14-2012, 12:10 PM   #48
By the way, some have mentioned that this is such a common question but I don't find anything in this site or any other site on power coming in to the middle switch. ...
The way I've tried to keep it simple about multi-way switching is by remembering schematically the common of one switch takes the hot line power, and the common of the other switch gives the line power to the load. Then all the travelers connect to each other respectively, regardless of whether there are any or how many 4-ways in the middle.
So it doesn't matter where the line power enters into the picture; you just need to "get" the hot line to one 3-way switch and "get back" the neutral from the load (and per 2011 NEC, create the neutral "bus" among all the switches too).
sixspeed is offline   Reply With Quote
Old 06-14-2012, 01:42 PM   #49
Rewards Points: 605
Code05, I do have a solution. Thanks. I wired it according to your diagram and it worked perfectly. Just wrapped it up now.
Thanks all for your help.
Dale
Old 06-14-2012, 02:20 PM   #50
Code05's Avatar
Dale
Wiring in a 4-way Switch RickSene Electrical 5 04-09-2013 08:25 PM
Illuminated switch ??? dave95sps Electrical 5 05-29-2011 06:11 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 07:43 PM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 02:24 AM
4 way switch confusion Richo Electrical 10 04-09-2009 08:11 AM
