3 Way Switch Power At Wrong End - Electrical - DIY Chatroom Home Improvement Forum
Old 10-26-2012, 01:35 PM   #1
3 Way switch power at wrong end
I am trying to help a friend that has a wiring issue. He has a properly functioning 3 way switch controlling 1 light. However, the power comes in at the wrong end. The 3 way at the other end is where he needs power to be brought in because there are three other switches/loads in this box that need to be tied into a constant power source. I think I need to make a white neutral hot from the opposite switch box back to/thru the light box and to the 3 way switch box where I need power, but not sure the best way to go about this. The power comes in at the opposite/wrong switch which is a single 3 way switch with no other loads or switches to worry about. Just exact opposite of what I need.
Can anyone help me out? Much appreciated!
Seahawk is offline   Reply With Quote
Old 10-26-2012, 01:56 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 380
You can not steal a neutral from anyplace.
Run a new cable from the existing 3 way to the 3 way you need power at.
jbfan is online now   Reply With Quote
Old 10-26-2012, 02:39 PM   #3
JB Fan, I cannot run a new circuit as this is a finished/closed wall and ceiling with no open access. The 3 way with the power is at the top of the stairs while the other end of the 3 way is at the bottom of the stairs across the room on the opposite wall. I would have to rip out sheet rock to do so.
This home has been remodeled, and I just cannot believe that this was overlooked and wired in this fashion. Is there no other way I can rewire the configuration between the light, and both 3 way switches to get a constant hot down to the other 3 way switch so that I can power the other 3 switches in that box?
Old 10-26-2012, 03:53 PM   #4
joed's Avatar
Rewards Points: 12,328
Then you need to rip out the sheet rock or find a different source for the power and may rip out less sheet rock. You can't just magically make a neutral wire appear.
The Following User Says Thank You to joed For This Useful Post:
Seahawk (10-26-2012)
Old 10-26-2012, 04:15 PM   #5
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Just use a Lutron Pico wireless switch, this will get you out of it without having to remove sheetrock.
The Following User Says Thank You to stickboy1375 For This Useful Post:
Installed new fixture. Power is getting to fixture. switch not turning power on and off sfrederi Electrical 1 10-21-2011 05:56 PM
2 way switch mystery.. no power at switch but power at light when turned on vote4Pedro Electrical 18 06-27-2011 10:25 PM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 01:24 AM
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 03:06 PM
3 Way Switch Draw additional Power? mattyd Electrical 15 03-24-2008 01:36 PM
