3 Way Switch With Pilot Light - Electrical - DIY Chatroom Home Improvement Forum
Old 01-06-2011, 12:22 PM   #1
3 way switch with pilot light
I am interested in installing a 3 way switch that has a pilot light in it. I've done a lot of research and want to make sure it will/won't work. The link contains my current setup and I would want to put the 3 ways switch with pilot in 3 way switch No. 1. Do I need to run an extra wire between the switches or will the pilot work as planned?
http://www.homeimprovementweb.com/in...ch-option5.htm
travesty is offline   Reply With Quote
Old 01-06-2011, 01:19 PM   #2
Rewards Points: 1,536
Is the switch light supposed to be on:
1. When the main light is on?
2. When the main light is off?
3. All the time?
Old 01-06-2011, 01:34 PM   #3
I would like the pilot light on the switch to be on when the main light is on.
The switch with the pilot light is in my living room, which controls the lights in the garage. The other three way switch is in the garage.
Old 01-06-2011, 02:10 PM   #4
joed's Avatar
Rewards Points: 13,308
Since switch #1 has the neutral it might work, but I don't think so since the switched power is in the other box. The other box has the switched power and the neutral so it should work there no problem.
Old 01-06-2011, 06:28 PM   #5
UHMmm
Both switches have power on them all the time through one of the travelers. In your diagram both boxes have neutrals in them. The internal connections in the switch take care of the lighted switch.
Watch....
Bob
Hourglass52 is offline   Reply With Quote
Old 01-06-2011, 06:38 PM   #6
Electrical Contractor
kbsparky's Avatar
You will need a 4-conductor cable between the 3-way switches in order for a pilot light switch to work at location #1.
-KB
Old 01-06-2011, 07:33 PM   #7
Where would this 4th wire hook up to??
This is not a 4 wire configuration. The switched common is the 14/2 going to the light/load. It is still 14/3 with 2 travelers and a neutral.
The switched common is not connected to the power common in the right box. If it was the light would never turn off.
The pilot light is internally connected in the switch. I have the part number somewhere.
Old 01-06-2011, 09:36 PM   #8
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,226
Your sketch shows 4 conductors between the switches. The OP only has 3.
Coastal South Carolina
Old 01-06-2011, 09:45 PM   #9
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Sorry Bob but Kbsparky is correct. Your going to need 4 wire cable between switches for a pilot light 3 way switch to work in the line position or switch one in the diagram. If I'm not mistaken even the diagram you posted has 4 wires.
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 01-07-2011, 06:00 AM   #10
You are rite
I didn't get the original op question. I thought he wanted both switches lit, load off. Your diagram makes sense to me.
Old 01-07-2011, 09:29 AM   #11
UAW SKILLED TRADES
Stubbie's Avatar
No problem Hourglass
Hey .. I really like your color choices for the travelers in your diagram ..
Stubbie
Old 01-07-2011, 09:42 AM   #12
I copied that from somewhere.
One of the problems I find with old work is don't get hung up on what color it is. Just pay attention to where is goes.
When I worked in Tennessee some times we pulled what ever color we had on the truck. I was just a kid then.
Bob
Old 01-18-2011, 12:38 PM   #13
Thanks for all the help guys. Those diagrams are a little over my head so I just used regular 3-way switches to complete my project. Thanks again.
How to diagnose gas valve problems Nestor_Kelebay How To Guides 28 10-30-2013 04:19 PM
Pilot Light works once, then have to re-light after furnace goes off aransas42 HVAC 8 09-30-2009 07:49 AM
pilot light confusion please help fastcarsca1 HVAC 4 10-04-2008 02:44 PM
Is a pilot light supose to stay on? simonb HVAC 2 06-11-2008 05:16 PM
pilot light reignition on older williams model Unregistered HVAC 1 02-17-2004 09:26 PM
