3 Way Switch With Pass Through Power Connection Issue - Electrical - DIY Chatroom Home Improvement Forum
Old 09-28-2010, 02:05 PM   #1
3 way switch with pass through power connection issue
Hi,
I had decided to change my dining room light from a single to a dual switch. The switch locations were on opposite sides of the room, so I decided to hook it up using a circuit where the light was in the middle.
I opened up the light box, and was surprised to see not only the original switch, but 2 other connections in the box. I cannot see the entire circuit for either connection, but one has to be the power, and there is another that continues on to connect with my kitchen light circuit. I will call this one other.
The way it was wired (when everything worked):
switch black to light black.
power white to other white to light white
power black to other black to switch white.
I have successfully gotten both of the 3 way switches to work perfectly, having been very happy about this I started putting things away, etc, but come to find out that the kitchen lights no longer work.
What I did to wire the 3 way switches was:
switch A red to switch B red
switch A white to switch B white (both taped black)
Power black to other black
Power white to other white to light white
Switch B black to light black
My question is, is although this works for my 3 way switched, is this correct, or is this somehow throwing off the power connection to my kitchen lights (along the "other" cable)?
When I check the power/other black connection and power/other white connection with my voltage meter it has power. However when I check the other end of that cable, it does not. I don't see anything wrong with the cable itself.
Thanks for any help.
Curt
ccmbee is offline   Reply With Quote
Old 09-28-2010, 02:30 PM   #2
joed's Avatar
Rewards Points: 13,308
Power black also needs to go to switch A black along with other black.
Old 09-28-2010, 02:38 PM   #3
My apologies, that is the way I have it. Switch A black is connected to power black and other black.
3-way switch help amit Electrical 17 02-15-2010 03:17 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
Pressure switch issue? or something else... rp4985 Plumbing 8 07-11-2009 02:31 PM
2 lights one switch, power to the switch . . . gregoryc Electrical 15 03-17-2009 10:46 PM
Power disconnect switch lmanwarren Electrical 1 03-28-2006 03:17 AM
