3-way Switch Issues - Electrical - DIY Chatroom Home Improvement Forum
Old 04-12-2010, 09:55 AM   #1
3-way Switch Issues
I am remodeling my kitchen. I have two switch boxes on opposite sides of the room. I have a 14/2 feed going into one box, that box has two switches - a 2-way that controls a single light and a 3-way that controls a few high hats. On the other side of the room I have the same setup. I have a 14/3 wire running between these boxes. How do I connect everything? I screwed something up because the 3-way switch on one side of the room is controlling both lights on the other side. Can someone tell me how to set this up or point me to a url with instructions.
melchiorkd is offline   Reply With Quote
Old 04-12-2010, 10:01 AM   #2
Just call me Andrew
Rewards Points: 1,020
So in the first box....two switches (single-pole for 1 light and 3-way for other high-hats) - got that.
What's in the second box? One switch or two? (You said you had the same setup on the other side of the room). If you have two switches in the second box, what is the non-3way for? Another light? If this is the case, you need another wire between your boxes. If you only have a single 3-wire cable between your switches, two of those are travelers, and the other is either a neutral or the feed to your light. You have no unswitched hot going to the second box to control an additional light solely from the second box.
Andrew
secutanudu is offline   Reply With Quote
Old 04-12-2010, 10:14 AM   #3
joed's Avatar
Rewards Points: 11,552
If you have the same setup in the second box - 3 way and single switch- then you can't do it. You don't have enough cables.
If you only have one switch in the second box then you also need to tell us the wire connections in the fixture controlled by the three ways, because you haven't told us about enough cables in either box that one would go to the fixture. The 3 wire cable must go through the fixture.
Old 04-12-2010, 11:28 AM   #4
Master Electrician
more info needed....take a look at stubbies diagrams at the top of the page...it's all drawn out there how to hook up a three way.
andrew79 is offline   Reply With Quote
Old 04-12-2010, 03:37 PM   #5
I have two switches in the second box, one 2-way and one 3-way. I thought I could power the 2-way and 3-way on the second box with the 14/3 from the other box.
Old 04-12-2010, 03:50 PM   #6
Master Electrician
nope....you need another wire.
Old 04-12-2010, 03:52 PM   #7
Just call me Andrew
Is the light you wish to control from 2 places fed from your second 3-way in box 2, or back from box 1?
Andrew
Old 04-12-2010, 07:04 PM   #8
joed's Avatar
Can't do it with 14/3. There will be no neutral. The three wires you have are all needed for the three way hot and 2 travellers.
Old 04-13-2010, 08:16 AM   #9
Thanks for your responses everyone. I ran a new 14/2 feed for the 2-way switch last night.
Wiring double switch for new ceiling fan toolmanwannabe Electrical 17 11-15-2011 10:34 PM
New pressure switch and inducer and still incorrect drafting kevintabb HVAC 5 01-19-2010 01:59 PM
HowTo: Adding two exterior lights + switch, piggyback new switch off existing switch? ghost Electrical 14 04-19-2009 06:04 PM
4 way switch confusion Richo Electrical 10 04-09-2009 08:11 AM
To Switch loop or not to switch loop beezlebub03 Electrical 7 06-17-2008 07:04 PM
