3 Way Switch Issue (after Replacement) - Electrical - DIY Chatroom Home Improvement Forum
Old 09-20-2010, 10:47 AM   #1
3 Way Switch Issue (after replacement)
I'm having some trouble after replacing a three way switch...
I have one switch that is a standard 3 way toggle and one that was an older dimmer. They switch the bottom of one outlet I have with a lamp plugged into it. Everything worked fine, until I went to switch out the dimmer!
Installed a new Lutron dimmer, and wired it the same way. Everything seemed to work fine with the switch wired up and still hanging from the wall.
I continued to then switch out all the outlets in that room with tamper proof outlets. No problems, straight forward swap out.
Turned back on the power after my work was done and had put the switch back into the wall, and noticed the dimmer switch doesn't work!
All the outlets work fine, but the switch does not work from either end anymore. I replaced the toggle, tried the old dimmer again, a different dimmer...nothing! Can't get it work even on the old set up. I feel like i've tried everything and wasted countless hours on this, checked all my wiring, even on all the outlets.
Why would a three way switch setup just stop working? All the wiring is the same....any ideas?
Thanks in advance.
mpukit is offline   Reply With Quote
Old 09-20-2010, 11:15 AM   #2
Just call me Andrew
Rewards Points: 1,020
If only half the outlet is switch-controlled, you probably need to break the little tab connecting the gold screws on the side of the outlet (but not the silver screws). Do you have the old outlet? If so, take a look at it and see which tabs, if any, are broken.
Andrew
secutanudu is offline   Reply With Quote
The Following User Says Thank You to secutanudu For This Useful Post:
mpukit (09-20-2010)
Old 09-20-2010, 11:23 AM   #3
" Euro " electrician
frenchelectrican's Avatar
One of the recetaple you will see a small brass tab between the two brass screw that part you will have to break off with needle nose piler and look at the junction box to see if you have red conductor if so that what you need to do it.
Merci,
Marc
The Following User Says Thank You to frenchelectrican For This Useful Post:
mpukit (09-20-2010)
Old 09-20-2010, 11:25 AM   #4
Just call me Andrew
I beat you to it, Marc!!!!
Andrew
Old 09-20-2010, 11:32 AM   #5
Yep you did I should drink little more Coffee.
Merci.
Marc
Old 09-20-2010, 11:34 AM   #6
To OP.,
Did the dimmer switch was used to the recepteale or that was go to the wall or ceiling luminaire ??
The reason why I ask due the Code do not allowed dimmer to be on the receptale unless you have special designed recpectale to be used conjuction with the dimmer.
Merci,
Marc
Old 09-20-2010, 11:34 AM   #7
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Secut... Gets a Gold Star
Marc.....Gets a Gold Star for bringing up the receptacle issue
Disclaimer
& Stay Safe
.....Bob Lavery
The Following User Says Thank You to PaliBob For This Useful Post:
frenchelectrican (09-20-2010)
Old 09-20-2010, 11:39 AM   #8
"They switch the bottom of one outlet I have" ....... "Installed a new Lutron dimmer."
Dimmers shouldn't control an outlet anyway. They're meant for only for permanently installed light fixtures. (by Code)
Plug a TV into the outlet, and you'll see why
alfred e neuman is offline   Reply With Quote
Old 09-20-2010, 01:33 PM   #9
Appreciate the quick replies. Makes sense...It must be the tab on the side, never noticed that!
The dimmer is connected to an outlet with a lamp plugged in, and has been that way since 1968. I know its probably not to code, but nothing but that lamp is ever plugged into this spot...I wouldn't plug my tv there.
Old 09-20-2010, 01:35 PM   #10
Just call me Andrew
You could get something like this....it would be to code, but probably not in the spot you want it if you're used to using the switch.
http://www.amazon.com/Lutron-TT-300N.../dp/B0000DI241
Andrew
Old 09-20-2010, 02:52 PM   #11
joed's Avatar
Rewards Points: 12,366
By code a dimmer can NOT be used to control a receptacle. You don't know what the next person might plug in. If you dimmed a tv you could let the smoke out. Once it's out you never get it back in.
Old 09-20-2010, 03:12 PM   #12
Thanks guys.
Condenser Fan Cycling Switch Replacement wirenut1110 HVAC 2 01-23-2010 09:29 AM
New pressure switch and inducer and still incorrect drafting kevintabb HVAC 5 01-19-2010 12:59 PM
Light Switch to Detached Garage - Grounding Issue smitty286 Electrical 1 10-22-2008 12:17 PM
ceiling fan dimmer switch issue irich Electrical 4 02-10-2008 10:23 PM
Ceiling Fan Light Switch Replacement leanthinkin Electrical 2 08-22-2006 12:10 PM
