3 Way Switch Issue - Electrical - DIY Chatroom Home Improvement Forum
Old 01-06-2012, 12:43 PM   #1
3 way switch issue
Hi all. I am installing a 3 way switch and am having a bit of an issue getting both to work properly. I followed the below diagram
Switch A has the main line coming in. In order for B to continue power to the lights A has to be switched on, even though there is no on off on a 3 way. If A is switched on B works just perfect. I am sure there is something with my traveler wire thats screwing this up but I can't find it.
If someone can pinpoint what is causing this issue it would be great.
handyandiknowit is offline   Reply With Quote
Old 01-06-2012, 01:15 PM   #2
MarginallyQualified
Rewards Points: 2,464
I'm not gonna trace what you have... except to confirm this sequence:
--> 2Wire Feed --> 3Way <--3Wire--> Light <--3Wire--> 3Way
Assuming that is all correct... do this:
At 1st Sw Box:
1) white from feed ties to white in the 3Wire
2) BLACK from 2W connects to 'point' terminal on 1st 3Way switch
3) Remaining Red and Black go to traveler terminals on 3way
At Light Box:
1) Red and Black wires get wirenutted together
1) White from 1st box = neutral and goes to fixture
3) White from 2nd sw box = "point", gets a piece of tape on it, and goes to fixture
At 2nd Switch Box:
White wire gets a piece of tape on it, then goes to "point" terminal.
Done.
hth
ps: What you have called "common" is the "point" wire.
Old 01-06-2012, 01:15 PM   #3
joed's Avatar
Rewards Points: 11,610
The diagram you posted is incorrect. The black screw(common) on the right switch should have the black wire not the white marked black.
Old 01-06-2012, 01:39 PM   #4
Rewards Points: 2,512
Yup...good catch Joed. He messed up the travelers with the common on the right switch.
Putting aside wire colors, the wire coming off the common terminal on the right switch should go directly to the light.
hammerlane is offline   Reply With Quote
Old 01-06-2012, 02:34 PM   #5
TY Tarheel. That did the fix and now the switches worked just fine. You da man.
Old 01-06-2012, 04:03 PM   #6
joed's Avatar
Originally Posted by TarheelTerp View Post
At Light Box:[/U]
At 2nd Switch Box:
Done.
hth
This is not code compliant. You now have two white wires going to the fixture. You must use the white(marked black) as the traveller and the black as the feed to the fixture.
Old 01-06-2012, 06:11 PM   #7
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,034
IMO, wiring the 3 conductor cable through the fixture box (although code compliant) is the most confusing way to go. Run the 3 wire cable directly from switch to switch.
Makes trouble shooting a lot easier.
Coastal South Carolina
motion sensor switch issue bkvanbek Electrical 2 12-16-2011 05:19 PM
Generator Transfer Switch Trouble wgramer Electrical 23 11-12-2011 08:23 PM
Bryant Rollout switch recurring issue TruckTahoe HVAC 3 01-24-2011 08:41 PM
1 pole + 3 way switch momof2labs Electrical 1 05-22-2010 11:37 AM
Just for fun Andy in ATL Electrical 56 10-20-2009 10:33 AM
