3 Way Switch Help Needed Asap - Electrical - DIY Chatroom Home Improvement Forum
Old 02-27-2011, 05:04 PM   #1
Rewards Points: 156
3 Way Switch help needed asap
Okay here is what I have. I have 14/2 running into my 3 way switch. Now in the same box I have 1 14/3 wire that runs up the stairs to another switch. Also on my box downstairs I have a 14/2 wire that runs directly to the light. I have no other wire running out of my upstairs box just the one 14/3 coming in. How do I hook this up. Here is what I did do. I connected the incoming power in this manner. All whites together (3)---Then (1)black wire on one of the terminals on the downstairs 3 way switch then the remaining two black wires are connected together on the other terminal then the red wire running solo on the other side of the switch. Now this bottom switch works but the upstairs switch does not work. It has power to the switch when the downstairs switch is turned on but when I turn the switch off then the power turns off to the switch upstairs. Must be something minor but I am stumped Thanks in advance.
ryan5068 is offline   Reply With Quote
Old 02-27-2011, 05:07 PM   #2
joed's Avatar
Rewards Points: 13,346
Old 02-27-2011, 07:19 PM   #3
Rewards Points: 156
i am having a difficult time following this diagram.
Old 02-27-2011, 07:34 PM   #4
Electrical Contractor
jbfan's Avatar
Rewards Points: 552
The black from the 14/2 into the first box connects to the common screw on the switch. This screw is a different color than the other screws.
The black in the 3 wire cable from the second sitch connects to the black wire going to the light.
The white from the 2 14/2 cables connect together.
At the other switch, connect the black to the common screw.
The white and red wires connect to the other screws.
Old 02-27-2011, 08:29 PM   #5
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Whats causing the difficulty? Maybe we can clear this up if Jbfan hasn't already.
The diagram Joe posted is exactly what you described.
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 02-27-2011, 08:56 PM   #6
Rewards Points: 156
You guys ROCK! It works like a charm. The diagram was kinda messing me up with the sharp angles (wire) I am not used to seeing it that way. Everything works as it should . Thanks a million!
Wiring in a 4-way Switch RickSene Electrical 6 05-13-2017 04:29 PM
Well Pump pressure switch help needed. slabm7 Electrical 20 11-03-2010 05:56 PM
Wiring 2 light fixtures to same switch and add outlet RyanS2000 Electrical 13 10-10-2010 02:17 AM
3-way switch help amit Electrical 17 02-15-2010 03:17 PM
4 way switch confusion Richo Electrical 10 04-09-2009 07:11 AM
